Thread Number: 27689
Maytag WHITE vs BLUE Deep Tub size |
Post# 424501   3/23/2010 at 22:44 (5,140 days old) by scrubflex (bronx, new york)   |   | |
Does anyone know ABSOLUTELY or POSITIVELY sure whether there IS or NOT a size difference between these two tubs? I thought the blue tubs were smaller. |
Post# 424502 , Reply# 1   3/23/2010 at 22:47 (5,140 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 424505 , Reply# 2   3/23/2010 at 23:02 (5,140 days old) by qsd-dan (West)   |   | |
Post# 424519 , Reply# 3   3/24/2010 at 00:55 (5,140 days old) by scrubflex (bronx, new york)   |   | |
The blue is nice but, is one deep tub bigger than the other. Tuesday I measured an A510 blue deep tub and it was 21" wide. But, I was told the white deep tub measured 21 1/2 to 21 3/4" wide. |
Post# 424520 , Reply# 4   3/24/2010 at 01:01 (5,140 days old) by scrubflex (bronx, new york)   |   | |
Dan, you have a couple of Magtag white deep tub washers. What about it, are the white tubs 21 1/2" or 21 3/4" wide? |
Post# 424529 , Reply# 5   3/24/2010 at 02:37 (5,140 days old) by alr2903 (TN)   |   | |
My A206 is the dark blue, small tub, in the 60's there were A106's that were dark blue with a white spreckle on them. In the beginning were all of the big tubs white, to create the illusion of bigger? alr2903 |
Post# 424563 , Reply# 7   3/24/2010 at 09:02 (5,140 days old) by scrubflex (bronx, new york)   |   | |
What "high fin agitator" in an older machine? |
Post# 424565 , Reply# 8   3/24/2010 at 09:19 (5,140 days old) by bajaespuma (Connecticut)   |   | |
Ditto.
Some of the lower-end MOL's in the Eighties had blue tubs...it was as if they were identifying the white porcelain tubs as a "deluxe" feature. TOL 'tags in the early sixties had white porcelain tubs that were identical in size to the A206 "regular" sized tubs. They're interchangeable. What I don't know is whether the white tubs have an extra coat of porcelain sprayed onto them making them a little more durable. The "elders" would probably know this. |
Post# 424583 , Reply# 9   3/24/2010 at 11:26 (5,140 days old) by Tomturbomatic (Beltsville, MD)   |   | |
The "High Fin" agitator was the design that Maytag first called the Gyrator and then later the Lint Filter Agitator. They were first red Bakelite, then black Bakelite. In the wringer washers they were even eventually made out of turquoise polypropylene. |
Post# 424688 , Reply# 10   3/24/2010 at 22:27 (5,139 days old) by qsd-dan (West)   |   | |
Both tubs measured out the same. I already knew the answer though as both white and blue tub machines use the same tub cover clamp and seal. Even the small tubs use the same clamp and tub cover seals as the tall tubs.
I highly doubt Maytag would have bothered to design a different tub with such slight dimensional changes. |
Post# 424700 , Reply# 11   3/24/2010 at 23:20 (5,139 days old) by scrubflex (bronx, new york)   |   | |
Huhmmm!!! |
Post# 424724 , Reply# 12   3/25/2010 at 02:47 (5,139 days old) by spankomatic (Ukiah,CA)   |   | |
