Thread Number: 27698
DE 702 parts help |
Post# 424643 , Reply# 1   3/24/2010 at 19:09 (5,145 days old) by Saltysam ()   |   | |
Every place I have looked either doesn't recognize the model number or they say parts are NLA. Here is a picture of the dryer from the front. |
Post# 424647 , Reply# 2   3/24/2010 at 19:19 (5,145 days old) by Saltysam ()   |   | |
a picture of the pulleys |
Post# 424648 , Reply# 3   3/24/2010 at 19:21 (5,145 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I assume you need the idler pulley you may need to replace the shaft also if it is worn or scored.The parts are NLA but you can use the idler and shaft from any HOH dryer you can also take the worn pulley & shaft to a machinist who make a new bearing and re-machine the worn shaft oh the fun of classic appliances.
Post# 424653 , Reply# 5   3/24/2010 at 20:42 (5,145 days old) by dnastrau (Lords Valley, PA)   |   | |
...just to be clear. Hopefully the pulley is the same part number. I'd look on the pulley for a number. It might be stamped as 3-840. |
Post# 424660 , Reply# 6   3/24/2010 at 20:52 (5,145 days old) by dnastrau (Lords Valley, PA)   |   | |
...as they also list it under parts for a DE700 which is older... CLICK HERE TO GO TO dnastrau's LINK |
Post# 424665 , Reply# 7   3/24/2010 at 21:06 (5,145 days old) by dnastrau (Lords Valley, PA)   |   | |
Listed as "Whirlpool" for the manufacturer but I think this is it also. CLICK HERE TO GO TO dnastrau's LINK |
Post# 424667 , Reply# 8   3/24/2010 at 21:14 (5,145 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 424679 , Reply# 9   3/24/2010 at 21:56 (5,145 days old) by Saltysam ()   |   | |
Awesome Andrew, thanks for the info! that definitely helps to have some part numbers to work with. Mark |
