Thread Number: 27744
Still looking for that perfect vintage Kenmore or Whirlpool |
Post# 425250 , Reply# 1   3/27/2010 at 20:41 (5,140 days old) by Gyrafoam (Wytheville, VA)   |   | |
How did that gorgeous '66 Whirly set get away from you? |
Post# 425917 , Reply# 4   3/31/2010 at 14:15 (5,136 days old) by washerlover (The Big Island, Hawai’i)   |   | |
Post# 425946 , Reply# 5   3/31/2010 at 17:56 (5,136 days old) by yogitunes (New Jersey)   |   | |
Post# 425950 , Reply# 6   3/31/2010 at 18:43 (5,136 days old) by yogitunes (New Jersey)   |   | |
Post# 425951 , Reply# 7   3/31/2010 at 18:47 (5,136 days old) by yogitunes (New Jersey)   |   | |
Post# 425953 , Reply# 8   3/31/2010 at 19:04 (5,136 days old) by yogitunes (New Jersey)   |   | |
NEXT.....what kind of drain application do you have?.....we have solutions for that also.....is it a 1 1/2 inch or 2 inch pipe?
schedule 40 pipe.....3/4 inch...a few elbows and a few cut pieces of straight pipe...a little glue...maybe a clamp or 2...and you have 2 hook ends that will connect to each drain hose and sit in the drain pipe side by side, with plenty of air gap.....we can rig anything....lol |
Post# 427284 , Reply# 10   4/6/2010 at 18:16 (5,130 days old) by yogitunes (New Jersey)   |   | |
Just make sure you have an anti-siphon valve if your running a hose direct into a floor drain, or elevate somehow, otherwise the machine will drain while its trying to fill....although a floor drain works best if its a solid tub machine....but otherwise yes, the floor drain should handle the water from the machine....
Post# 427834 , Reply# 12   4/9/2010 at 19:38 (5,127 days old) by yogitunes (New Jersey)   |   | |
