Thread Number: 27780
Got home this evening with Vintage set #2! |
Post# 425659 , Reply# 1   3/29/2010 at 23:19 (5,140 days old) by randycmaynard ()   |   | |
Inside. |
Post# 425660 , Reply# 2   3/29/2010 at 23:20 (5,140 days old) by randycmaynard ()   |   | |
2nd Inside shot - through glass in door. |
Post# 425661 , Reply# 3   3/29/2010 at 23:21 (5,140 days old) by randycmaynard ()   |   | |
Main control. |
Post# 425662 , Reply# 4   3/29/2010 at 23:22 (5,140 days old) by randycmaynard ()   |   | |
Dryer view. |
Post# 425663 , Reply# 5   3/29/2010 at 23:23 (5,140 days old) by randycmaynard ()   |   | |
Dryer main control. |
Post# 425666 , Reply# 6   3/29/2010 at 23:24 (5,140 days old) by randycmaynard ()   |   | |
Weigh to Save load size indicator on washer. |
Post# 425667 , Reply# 7   3/29/2010 at 23:26 (5,140 days old) by randycmaynard ()   |   | |
Well that's all for tonight/morning.... will post more as I get things situated, up and running! |
Post# 425713 , Reply# 9   3/30/2010 at 07:35 (5,140 days old) by dynaflow (rockingham nc)   |   | |
Post# 425731 , Reply# 10   3/30/2010 at 10:14 (5,139 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 425816 , Reply# 11   3/30/2010 at 20:33 (5,139 days old) by kenmorekeith ()   |   | |
I was going to say late 80's -90 my mom had one in the 80's and the timer didnt look like that!! I really want to say its from the 90's |
Post# 425857 , Reply# 12   3/31/2010 at 06:22 (5,139 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 425865 , Reply# 13   3/31/2010 at 06:53 (5,139 days old) by dnastrau (Lords Valley, PA)   |   | |
Back in the late '90's friends had a set of these that were thoroughly worn out. I helped him take them to the dump and that was the heaviest washer I have ever moved. |
Post# 425876 , Reply# 14   3/31/2010 at 08:10 (5,139 days old) by randycmaynard ()   |   | |
as heavy as this little westy.... two of us got it into my truck bed and took three to get it out and over to its temp place in the garage. Definatly one heavy little beast! |
Post# 425895 , Reply# 15   3/31/2010 at 10:47 (5,138 days old) by mickeyd (Hamburg NY)   |   | |
Post# 425915 , Reply# 16   3/31/2010 at 13:49 (5,138 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
I would have to agree it looks to be "newer". I have a 1994 White Westy set (photo) and as you can see the control panel looks very similer. Mine does not have the "Weigh-to-Save" door however. Plug it in and put it into spin. If it makes a loud "clunk" and ramps right up to speed it's the older drive system. If you hear a seperate pump come on and it takes 30 seconds or so to start ramping up to speed, it's the "newer" drive system like mine. I actually have both a 1990 and a 1994 version and they have a variable speed, reversing DC motor. It's much quietier and it will "reverse-tumble" when washing or rinsing. (I think, though I don't know for sure, they changed to the "newer" drive system in the mid-late 80's.) Kevin |
Post# 425931 , Reply# 17   3/31/2010 at 15:49 (5,138 days old) by askomiele (Belgium Ghent)   |   | |
When you talked about driving systems... I immediatly thought about that potatoepully they talked about so much in the past. What is it and what's the benefit? |
Post# 425943 , Reply# 19   3/31/2010 at 17:49 (5,138 days old) by yogitunes (New Jersey)   |   | |
Post# 425956 , Reply# 20   3/31/2010 at 19:20 (5,138 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The models you have were made from 1984-june 1988 the new drive system came out in 1989 and ended in early 1994. The three belt machine was a fun washer and much more durable than the single belt models.Either baffle can be removed and the sump baffle can be unscrewed and pushed to the left and the sump strainer can be cleaned and also the bottom of the tub.
Post# 425958 , Reply# 21   3/31/2010 at 19:34 (5,138 days old) by stainfighter (Columbia, SC)   |   | |
Post# 425962 , Reply# 22   3/31/2010 at 20:15 (5,138 days old) by golittlesport (California)   |   | |
Post# 426252 , Reply# 29   4/2/2010 at 03:43 (5,137 days old) by stainfighter (Columbia, SC)   |   | |
