Thread Number: 27783
Spider Arm woes.... |
Post# 425706   3/30/2010 at 05:58 (5,112 days old) by aaronfitzy (Pennsylvania)   |   | |
I was just sitting here, and thought..."why don't these manufacturers keep the aluminum arm, but before installing them...coat them with some sort of plastic?" I would think this would solve the failure of the spider arm on alot of the FL's. Hmmm....either that or they want it to fail in 5 years.
Aaron |
Post# 425712 , Reply# 1   3/30/2010 at 07:26 (5,111 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
Post# 425732 , Reply# 3   3/30/2010 at 10:25 (5,111 days old) by logixx (Germany)   |   | |
Post# 425934 , Reply# 8   3/31/2010 at 16:32 (5,110 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 426007 , Reply# 11   4/1/2010 at 04:23 (5,110 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
is the same, combination of metals & aluminium, in machines over here anyway, which is interesting because water softeners arnt a big thing here and so the powders would have to act as the water softener...the other thing we dont use is LCB...all of my vintage FL`s are running fine with no spider issues except for two 1970`s 18 series Hotpoint, which where particularly thinly made, & more likely to have been the stress of a fast spinning poorly balanced machine causing extra vibrations & stress on this particular spider..
Makes you think it more likely to be LCB without enough flushing rinses to clear away residues, I also wonder if its got to do with higher ambient temperatures and humidity levels over a longer period of time etc..(which freezing rainy snowy UK doesnt have..LOL) |
Post# 426083 , Reply# 14   4/1/2010 at 11:10 (5,109 days old) by favorit ()   |   | |
Soon we'll be given appliances as gifts when buying magazines, instead of DVD and books :) |
Post# 426295 , Reply# 15   4/2/2010 at 08:40 (5,108 days old) by vivalalavatrice ()   |   | |
Less than the PC Hard disk I bought few months ago... 199euros! |
Post# 426306 , Reply# 16   4/2/2010 at 10:38 (5,108 days old) by favorit ()   |   | |
"........after you'll have heard our message this washer will self-destroy within ten seconds" LOL |
Post# 426399 , Reply# 20   4/2/2010 at 18:40 (5,108 days old) by appnut (TX)   |   | |
Well Mark, I've not put one drop of LCB in my Fridgemore (3.1 cu. ft.). I turn the water heater up to 155 degrees and use oxyclean. In fact, I quit using LCB in the Lady Shredmore and started a long soak with OxyClean. BTW mark, don't you use your Sanitize Cycle?--it should pretty much eliminate the need for LCB. It's just too caustic to machinery and damaging to fibers!!! In fact, my whites aren't wearing out as fast either now.
