Thread Number: 27891
Westy deja vu?? |
Post# 427201   4/6/2010 at 14:36 (5,132 days old) by turquoisedude (.)   |   | |
History does repeat itself sometimes... Just about a year ago, I got my first Westy Laundromat (the L5) from Tampa and it spent most of the summer in various stages of dissambly in the garage - here we are a year later and the Canadian Westy Laundromat I got last August is now undergoing its turn in the restoration process!!
Post# 427203 , Reply# 1   4/6/2010 at 14:39 (5,132 days old) by rp2813 (Sannazay)   |   | |
Post# 427204 , Reply# 2   4/6/2010 at 14:41 (5,132 days old) by turquoisedude (.)   |   | |
There's nothing like having worked on a similar machine already! Knowing the insides of the Westy Laundromat made it a snap to disassemble (fortunately, I got to decide when the tub would come off with this one!!).
I knew I had a motor that wouldn't run, so I wanted to extract it for testing andI knew the door boot was in really bad shape so I would have to take the tub apart to temove it. Step 1 was taking the tub assembly out and it went very smoothly. This tub is still in really great shape, too!! |
Post# 427205 , Reply# 3   4/6/2010 at 14:44 (5,132 days old) by turquoisedude (.)   |   | |
Post# 427207 , Reply# 4   4/6/2010 at 14:47 (5,132 days old) by turquoisedude (.)   |   | |
I got the motor out easily enough and hooked it up; it buzzed but didn't turn. I gave the drive pulley a twist and the motor ran! I could not make it run without an assist, though. Like the motor from the matching dryer, I suspect it needs a good cleaning. I took it into the motor repair place in Magog where they brought the dryer motor back to life; I hope to hear back from them about it next week...
Post# 427209 , Reply# 5   4/6/2010 at 14:49 (5,132 days old) by turquoisedude (.)   |   | |
Post# 427210 , Reply# 6   4/6/2010 at 14:52 (5,132 days old) by turquoisedude (.)   |   | |
Post# 427212 , Reply# 7   4/6/2010 at 14:53 (5,132 days old) by turquoisedude (.)   |   | |
Post# 427218 , Reply# 8   4/6/2010 at 14:58 (5,132 days old) by turquoisedude (.)   |   | |
I can't believe how nicely the cabinet cleaned up! I don't think that I am going to repaint it after all. I may need to repaint the top cover and the front access panels, but I will try cleaning them up first, too.
Oh and I have to come clean, too... I thought this was a model CL-8, but when I could actually get a good look at the name and model number plate I discovered this a CLB-6! OOOPS! I also discovered the 'birthday' of the machine - May 29, 1953. It'll turn 57 soon!! |
Post# 427220 , Reply# 9   4/6/2010 at 15:03 (5,132 days old) by turquoisedude (.)   |   | |
I still would like to do an oil change on the speed changer unit. It seems to run fine, but I figure it will be worth it. Also, I need to work on the water solenoids. Initial testing wasn't conclusive, so I am going to make one (and only one) attempt to open up the solenoid and clean it out. Any signs of trouble after that and I will replace it with a 'modern' one like I did with the L5.
And, of course, I will have to do some reverse engineering on the door gasket to make it seal properly because I am using a door boot that is not the exact match for this machine. Despite all of this, I think I can get this beauty washing again by the end of May! Well, unless the job offer I got last week does turn out to be legit... |
Post# 427223 , Reply# 10   4/6/2010 at 15:07 (5,132 days old) by laundromat (Hilo, Hawaii)   |   | |
I would like to see Electrolux take that design,modify it a bit and reintroduce the Laundromat washers and dryers to the public!They are,by far,the best design in automatic washers (not necessarily the best one way tumblers) ever introduced and,as long as they were used and well maintained,they would last a generation.We all know this from our own experiences with the Laundromats.Wouldn't it be so fabulous for them to bring the laundromats back???!!!!
Post# 427242 , Reply# 11   4/6/2010 at 15:37 (5,132 days old) by turquoisedude (.)   |   | |
Post# 427251 , Reply# 12   4/6/2010 at 16:17 (5,132 days old) by customline (pennsylvania)   |   | |
Can't wait to see it kicked into action. |
Post# 427717 , Reply# 14   4/9/2010 at 08:03 (5,130 days old) by turquoisedude (.)   |   | |
The door boot I have is a style Q-4699 which I believe is for the space-mates (I have a couple of spares, too). I thought it would sub for the Q-4688... However, I did manage to jury-rig the door gasket on the L5 with some closed-cell weatherstripping to form a tight seal. Not pretty, but it works! I will use the same trick on the CLB-6.
Post# 429021 , Reply# 15   4/15/2010 at 13:25 (5,123 days old) by turquoisedude (.)   |   | |
Post# 430022 , Reply# 16   4/19/2010 at 20:10 (5,119 days old) by turquoisedude (.)   |   | |
And being the 'never happy to leave well enough alone' type that I am, I figured that it would be a good idea to change the wiring leading into the motor 'cause it was kinda brittle... EEESH! I struggled to get the cover plate off and managed to crumble off most of the insulation of the red and white wires. Even worse, I could not clearly see where I could re-attach new wires and I was not about to start messing around with the windings. It took me a while, but I finally decided to try slipping insulating tubes on the wires that were exposed and taping them into place. Thank goodness the black wire was intact 'cause I had a time getting the newly-insulated wires through the cover plate! The motor wiring is shown in the photo - not pretty but by jove, it works and I did not get electrocuted in the process! Note to self - make sure the washer is well-grounded for testing... LOL
Post# 430024 , Reply# 17   4/19/2010 at 20:13 (5,119 days old) by turquoisedude (.)   |   | |
I noticed a problem with the outer tub, though. The inside rim was raised for some reason and would probably have leaked water badly. A coat of JB Weld took care of that! I did manage to get the tub back together by the end of the day Sunday (no photo of that). With any luck, I will be able to water-test it this coming weekend...
Post# 430025 , Reply# 18   4/19/2010 at 20:14 (5,119 days old) by turquoisedude (.)   |   | |
Post# 431442 , Reply# 19   4/26/2010 at 21:43 (5,112 days old) by turquoisedude (.)   |   | |
Post# 431444 , Reply# 20   4/26/2010 at 21:45 (5,112 days old) by turquoisedude (.)   |   | |
Post# 431445 , Reply# 21   4/26/2010 at 21:48 (5,112 days old) by turquoisedude (.)   |   | |
I figured it would be a good idea to check the timer again - it ran through a whole 'cycle' just fine. Wow - a working timer! Last thing I did for this week was to wire in a new power cord and I had to change one of the disconnect terminals on the timer (it had broken). Stay tuned for the reassembly!!
Post# 431521 , Reply# 22   4/27/2010 at 07:39 (5,112 days old) by golittlesport (California)   |   | |
Post# 431624 , Reply# 23   4/27/2010 at 20:41 (5,111 days old) by turquoisedude (.)   |   | |
