Thread Number: 27942
Miele washer -- setting higher water level? |
Post# 427806 , Reply# 1   4/9/2010 at 17:36 (5,122 days old) by Pulsator (Saint Joseph, MI)   |   | |
There is a way to set the sensitive option to change the way it works. I have a W1215 myself and decided to get the Sensitive option changed.
Option 1 (the factory setting)-One extra low level rinse Option 2 -Change the wash and rinse water levels to high. (This high water level is not as high as the delicates level, but it does fill a little bit onto the door boot. Option 3 (the one I opted for) -Changes the wash and rinse water levels to high (same as option 2) but also adds a third rinse. I can't remember how the tech walked me through how to change the sensitive option, but it can be done and Miele walked me through it. If you call them and say you want the Sensitive option changed because things aren't getting rinsed well enough with the extra low level rinse and you mention that you know there is a way to raise the water levels on all water changes aside from the soak, they should walk you through how to do it. Hope this helps!!! :) |
Post# 427812 , Reply# 2   4/9/2010 at 17:58 (5,122 days old) by eddy1210 (Burnaby BC Canada)   |   | |
Post# 427819 , Reply# 4   4/9/2010 at 18:32 (5,122 days old) by eddy1210 (Burnaby BC Canada)   |   | |
Post# 427826 , Reply# 5   4/9/2010 at 19:11 (5,122 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 427935 , Reply# 9   4/10/2010 at 14:55 (5,121 days old) by Pulsator (Saint Joseph, MI)   |   | |
WOW!!! I LOVE this soft water rinse option!!! I turned that on and did a load consisting of 1 bath towel, 2 hand towels, and 5 wash cloths. Look at how much water it used for only 2 rinses! I know the water looks murky and sudsy, but the 2nd rinse was without a doubt the clearest rinse I have ever seen on a front load washer. The only machine comparable in my experience would be my double rinse Unimatic and only if I had used both a very small amount of HE detergent and a very large dosage of fabric softener. The rinse came up about 1/3 of the way up the window in the washer, the same level as the delicate cycle! I can't even begin to imagine how fabulous it would rinse if I turned on the sensitive option!!!!
Post# 427961 , Reply# 11   4/10/2010 at 17:31 (5,121 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 427979 , Reply# 12   4/10/2010 at 20:59 (5,121 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 427982 , Reply# 13   4/10/2010 at 21:21 (5,121 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 427992 , Reply# 14   4/10/2010 at 22:48 (5,121 days old) by eddy1210 (Burnaby BC Canada)   |   | |
Post# 427996 , Reply# 15   4/10/2010 at 23:15 (5,121 days old) by Tomturbomatic (Beltsville, MD)   |   | |
Eddy gave me the special steps to get three high level rinses in my W1986. The owner's manual gave the programming steps to get extra rinses and high water levels in the rinses with the W1918, but not the 1986. Eddy is a hero in my book. |
Post# 427999 , Reply# 16   4/10/2010 at 23:35 (5,121 days old) by eddy1210 (Burnaby BC Canada)   |   | |
Post# 428007 , Reply# 17   4/11/2010 at 00:04 (5,121 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 428086 , Reply# 19   4/11/2010 at 14:59 (5,120 days old) by eddy1210 (Burnaby BC Canada)   |   | |
Hi Holly, apparently some of the other settings will "screw up" for lack of a better word the operation of your machine (according to my sources) ie, country settings change the voltage/amp ratings and you wouldn't want to do that. And the heater ratings/ unbalance parameters should be left as they are set from the factory. But things you could change like soak time and buzzer loudness may be helpful. Some like to add the water cooling after the main wash to cool and also dilute the suds. That's one I choose. I've never tried enabling the allergy sufferers program so I don't know what that would do. Glad to hear you succeeded raising the rinse levels, I think you'll be very happy with the results, especially if you use the sensitive for an extra rinse and slightly higher water levels in the prewash and main wash.
Post# 428104 , Reply# 20   4/11/2010 at 16:38 (5,120 days old) by mrboilwash (Munich,Germany)   |   | |
could somebody guide me through the "soft water option", please ?
I have a German Miele W 435. It has been set to "soft water mode" by a service tech via a laptop computer. So far I am very happy with those high level rinses, but would love to have more control about it. (Going back to factory settings just for fun). However, the ownwers manual does not give any directions as to change the maximum rinse level. |
Post# 428182 , Reply# 22   4/12/2010 at 00:53 (5,120 days old) by vintagesearch ()   |   | |
wooooooooooooooooow that miele is impressive a bit more water is better IMHO |
Post# 428194 , Reply# 26   4/12/2010 at 04:44 (5,120 days old) by mrboilwash (Munich,Germany)   |   | |
Post# 428227 , Reply# 27   4/12/2010 at 08:48 (5,119 days old) by rayjay (Carteret, New Jersey)   |   | |
Hi. I think it was posted before, but I copied it and cannot find it. I am looling to buy the 4842 and I think someone posted on how to make the water level higher in all cycyles on this model. Can you help or post again? Thanks so much Ray |
Post# 428231 , Reply# 28   4/12/2010 at 09:41 (5,119 days old) by mieleforme ()   |   | |
Rayjay I sent you a copy of the service manual. |
Post# 428246 , Reply# 29   4/12/2010 at 12:11 (5,119 days old) by eddy1210 (Burnaby BC Canada)   |   | |
I think your machine will only allow you to toggle between hot mains intake and cold mains intake, I think the other 2 are disabled on the North American machines (see Favorit's comment about the Allwater machine made but only available in Europe) If you choose the cold, you will end up with a longer wash time as it stops to heat the water to the correct temp. Don't feel guilty about adding a third rinse, especially for heavy fabrics and those diapers, you want them rinsed very well. Glad you're happy with the results!
