Thread Number: 28002
Miele W3033 Insides |
Post# 428566 , Reply# 1   4/13/2010 at 22:31 (5,097 days old) by vacfanatic ()   |   | |
Post# 428567 , Reply# 2   4/13/2010 at 22:32 (5,097 days old) by vacfanatic ()   |   | |
Post# 428568 , Reply# 3   4/13/2010 at 22:33 (5,097 days old) by vacfanatic ()   |   | |
Post# 428569 , Reply# 4   4/13/2010 at 22:34 (5,097 days old) by vacfanatic ()   |   | |
Post# 428571 , Reply# 5   4/13/2010 at 22:36 (5,097 days old) by vacfanatic ()   |   | |
Post# 428572 , Reply# 6   4/13/2010 at 22:37 (5,097 days old) by vacfanatic ()   |   | |
Post# 428577 , Reply# 7   4/13/2010 at 22:39 (5,097 days old) by vacfanatic ()   |   | |
Bad press fit connection - happens, can't get too upset. Nothing is perfect in life :) It's fixed now! |
Post# 428579 , Reply# 8   4/13/2010 at 22:41 (5,097 days old) by vacfanatic ()   |   | |
Post# 428581 , Reply# 10   4/13/2010 at 22:48 (5,097 days old) by vacfanatic ()   |   | |
Bottom view of the watercontrol system. |
Post# 428582 , Reply# 11   4/13/2010 at 22:50 (5,097 days old) by vacfanatic ()   |   | |
Wireless network adapter |
Post# 428583 , Reply# 12   4/13/2010 at 22:51 (5,097 days old) by vacfanatic ()   |   | |
Drain pump and wiring harness connector under cover that connects the 220 volt transformer to the rest of the unit. |
Post# 428584 , Reply# 13   4/13/2010 at 22:52 (5,097 days old) by vacfanatic ()   |   | |
Post# 428585 , Reply# 14   4/13/2010 at 22:53 (5,097 days old) by vacfanatic ()   |   | |
Post# 428586 , Reply# 15   4/13/2010 at 22:53 (5,097 days old) by vacfanatic ()   |   | |
Post# 428588 , Reply# 17   4/13/2010 at 22:58 (5,097 days old) by vacfanatic ()   |   | |
Air pressure assembly, which routes to the imbalance gizmo above, and then to the main board pressure switch. |
Post# 428590 , Reply# 18   4/13/2010 at 23:00 (5,097 days old) by vacfanatic ()   |   | |
1060 Watt Heater Assembly - 159F / 70C Max, and it actually reaches target temps, unlike LG's :) Thermistor is in the middle with the brown wires. |
Post# 428593 , Reply# 20   4/13/2010 at 23:05 (5,097 days old) by vacfanatic ()   |   | |
Bored yet? I'm not, I need a Miele Intervention. Let's continue. :) |
Post# 428595 , Reply# 21   4/13/2010 at 23:08 (5,097 days old) by vacfanatic ()   |   | |
Sump float. If anything starts leaking, water will pool in the sump area and send a may-day to the mainboard. Display will say "Waterproof system activated". This better not happen until I'm about 50... |
Post# 428596 , Reply# 22   4/13/2010 at 23:10 (5,097 days old) by vacfanatic ()   |   | |
Warning! |
Post# 428598 , Reply# 23   4/13/2010 at 23:12 (5,097 days old) by vacfanatic ()   |   | |
Induction motor - quiet, reliable, and no carbons to wear out. |
Post# 428599 , Reply# 24   4/13/2010 at 23:12 (5,097 days old) by vacfanatic ()   |   | |
Post# 428600 , Reply# 25   4/13/2010 at 23:13 (5,097 days old) by vacfanatic ()   |   | |
Post# 428601 , Reply# 26   4/13/2010 at 23:15 (5,097 days old) by vacfanatic ()   |   | |
Pretty drum... |
Post# 428604 , Reply# 27   4/13/2010 at 23:19 (5,097 days old) by vacfanatic ()   |   | |
Ok I'm done :) Thought you all would like to get an inside view of a Miele. I've scoured the internet for photos of similar models but they are very hard to find. Wanted to share the inner workings! Andrew |
Post# 428613 , Reply# 28   4/14/2010 at 00:35 (5,097 days old) by bewitched (Italy)   |   | |
It's simply wonderful! In my opinion nothing can compare with Miele care in building its machines. I'd love to have a look inside my W4446 too! :-) Thanks for the beautiful photos! |
Post# 428623 , Reply# 29   4/14/2010 at 02:07 (5,097 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 428639 , Reply# 31   4/14/2010 at 04:33 (5,097 days old) by askomiele (Belgium Ghent)   |   | |
Is'nt that the pressure switch telling the controlboard the waterlevel in the drum? That washer is so clean and new! It's a dream! And yes the MIELE logo is sooo sexy! ;) |
Post# 428643 , Reply# 32   4/14/2010 at 07:04 (5,097 days old) by surgilator_68 (Maryland)   |   | |
Post# 428700 , Reply# 37   4/14/2010 at 11:34 (5,097 days old) by DysonAnimal ()   |   | |
...wouldn't you rather have one of these? :P |
Post# 428701 , Reply# 38   4/14/2010 at 11:35 (5,097 days old) by vacfanatic ()   |   | |
If it has a LED drum light and a wireless port, yes! LOL |
