Any recent model Speed Queen experts in the house?
We need to know if the graphic panels and control panel wiring harnesses are interchangeable between Alliance's AWS75N and AWS76N washers.
The only difference should be the temperature switch (3-position for the newer AWS76, and 4 positions for the older AWS75), but we're hoping someone can confirm this assumption.
Long story short, we installed extra plumbing to accomodate a warm water rinse in our AWS76, but we'd like to get rid of this plumbing and just replace the switch and graphic panel with their AWS75 counterparts.
We already have the part numbers to order, all we need to know is if the graphic panels are interchangeable, and if any wiring harnesses need to be modified to use the new 4-position temperature switch.
