Thread Number: 28074
Whirlpool's mistake |
Post# 429689 , Reply# 1   4/18/2010 at 17:59 (5,092 days old) by supersurgilator (Indiana)   |   | |
This video shows a early 2000 model which doesn't make this noise when shifting gears. CLICK HERE TO GO TO supersurgilator's LINK |
Post# 429690 , Reply# 2   4/18/2010 at 18:01 (5,092 days old) by supersurgilator (Indiana)   |   | |
This is a vid of the new Maytag cenntennial which now makes that banging noise when shifting gears. CLICK HERE TO GO TO supersurgilator's LINK |
Post# 429698 , Reply# 3   4/18/2010 at 18:44 (5,092 days old) by appnut (TX)   |   | |
The first video, the reason why it stopped spinning during the middle of the spin cycle is because it (1) wasn't doing a neutral drain, but was spinning while it drained, which it isn't supposed to do, unless it's a very early direct drive model, which it could be. The problem (2) is that it's no longer pausing long enough for the coupler to reconnect after it's impropoerly spin/draining. and when the machine shuts off, that loud bang that you hear is the coupler engaging before the rpms of the motor have slowed down enough. THAT is a verry normal noise and my 1986 Lady Shredmore did that same noise when the coupler engaged before the motor slowed down enough like it was supposed to, but it didn't do that on every spin by no means. Also, the lound bang could be something related to the transmission, which siomeone more techniical here is ogiong to have to address. That same bang could also be something in the transmission that weakens over time and prevents it from doing a continued neutral drain (like my Shredmore did) and soon after it starts draining, then it makes that "bang" as it also begins to spin. That's a noise from the transmission. OK DD experts elaborate on this please.
Post# 429752 , Reply# 4   4/18/2010 at 22:44 (5,092 days old) by surgilator_68 (Maryland)   |   | |
Bob: What coupler is there that has to reconnect with anything?
Bruce: If you want to keep your Kenmore put a transmission in it. The newer machines are supposed to have a lighter weight oil in them which in turn makes everything slide in and out of position easier and with less load on the motor, lowering amp draw. At some point the machinery for manufacturing the transmission parts was worn and the tolerances were out of spec. This caused various problems for some years. Supposedly manufacturing overhauled the tooling machines and brought everything back into spec. I will admit we have not seen the failure rate that we were seeing since Wpl bought Maytag which is around the time the transmission tooling overhaul happened. So with that information I can surmise that the new transmissions, while noisy are just fine. It's just the lighter weight oil letting things move around easier. |
Post# 429895 , Reply# 6   4/19/2010 at 11:14 (5,091 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Maybe I'm missing something here, but the 1993 DD Kenmore I have makes a pretty loud 'pop' as the motor turns off just prior to it re-starting for spin. Mine has never been quiet in that function and I figured it was supposed to be that way? I got it new as a scratch-n-dent machine. It saw very limited use 1993-1997 (like maybe two-three loads a month) then saw regular service for two years in 2006-2008, so it is certainly not worn yet. In fact, when I put it back in service in 2006 I did some of the first back to back loads with it and could smell a 'new smell' as the motor warmed up.
Unless I'm missing something, that pop sound during the preamble to spin seems normal to me. Gordon |
Post# 429942 , Reply# 8   4/19/2010 at 14:18 (5,091 days old) by DADoES (TX, U.S. of A.)   |   | |
The clunk noise is a normal part of the transmission shifting from neutral drain to spin. The 2nd video cited above does make the clunk, but it happens at the end of neutral drain when the motor is coasting to a stop. Notice that the basket shifts into spin at that moment and rotates slightly with the motor and tranny's remaining inertia. It's already fully shifted to spin when the motor restarts which is why the clunk doesn't occur then. There may also be a clunk/bang sound when the brake engages/disengages as in the 1st clip. That machine is definitely having a mechanical problem in regards to spin not resuming. |
Post# 429946 , Reply# 9   4/19/2010 at 14:29 (5,091 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
And our 1993 Whirlpool TOL set makes that same clunk (only a little bit louder) when it goes into spin. Our pump during the neutral drain sounds exactly like the one in the video. |
Post# 429963 , Reply# 10   4/19/2010 at 16:22 (5,091 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 429985 , Reply# 11   4/19/2010 at 17:51 (5,091 days old) by surgilator_68 (Maryland)   |   | |
The bang is normal.
The motor coupling does not engage anything. It is not designed to slip or engage or disengage. It merely couples the motor to the transmission. There are 3 fingers on each half of the coupling which mate to the rubber in the middle. There is not supposed to be any play, slipping or excessive movement between the 3 parts. If there is then the coupling is worn and needs to be replaced. |
Post# 430007 , Reply# 12   4/19/2010 at 19:22 (5,091 days old) by rll70sman (Hastings, Minnesota)   |   | |
I stand corrected in my verbiage. There is definitely nothing to be worried about, as the others here have stated. But, if you're going to buy another machine that is reasonably priced, stick with the Whirlpool family of brands. |
Post# 430379 , Reply# 14   4/21/2010 at 14:27 (5,089 days old) by DADoES (TX, U.S. of A.)   |   | |
I doubt there's anything specific can be done to control the noise. As others have told you above, including a working service tech, the variations are normal ... probably related to temperature/consistency of the transmission oil, wear-in of parts, and individual machine characteristics. In my experience with several neutral-drain specimens, the same machine may sometimes shift into spin "early" during the pause coast-down, and sometimes not. The clunk/bang noise may be prominent at times and less-so at other times. It's no different than the infamous grrrrrkk sound of a belt-drive wag-wag shifting, which may be quite noticeable in some cases and less-so in others depending on how far the wig-wag moves from the moment the solenoid energizes until the pin engages in the cam bar slot. |
Post# 1159377 , Reply# 15   9/12/2022 at 09:46 (562 days old) by GELaundry4ever (Nacogdoches, TX, USA)   |   | |
Sorry. I don't mean to revive this thread, but when did whirlpool go to a lighter oil? The maytag commercial energy advantages on my dorm does this too. |
Post# 1159378 , Reply# 16   9/12/2022 at 09:52 (562 days old) by luxflairguy (Wilmington NC)   |   | |
THEN WHY DID YOU? |
Post# 1159419 , Reply# 19   9/12/2022 at 19:44 (562 days old) by chetlaham (United States)   |   | |
Is very common, sometimes since day one.
In fact I originally had no clue that DDs neutral drained. They very first DD I ever got to study and take apart was from the mid-80s and made to spin drain right out of the factory. The latter model DDs I happened to use or encounter spun drain despite the 4 second motor pause in between. This lead me to think it was normal which put me in really embarrassing situations with repair techs and sales people. I remember on more than one occasion a salesmen on the Sears floor would tell me about the benefits of Kenmore's neutral draining and I would correct him saying they most certainly did not. He told me they did, and I would drone on about the pump being attached directly to the drive motor, that there was no separate drain pump, no actuation solenoid or hydraulic timing plungers in the transmission, that he had never actually taken one apart like I have... Given that personal experiences have lead me to believe people aren't always right in their world view or conducive to the equality of others the debates would get quite passionate LOL. Its embarrassing to think about how I was wrong and became all worked up over a disagreement. I went as far as once emailing Sears their manuals were wrong lol. It was not 5 years latter that when I read about the neutral drain gear that I actually con considered the possibility, with personal confirmation coming latter. Between 2007-2013 I swapped several DDs- 2 used and one new, all 3 would go into spin-drain on the first spin when using the delicate cycle. @Maytaga806: I would call this a blessing. It does not bother the transmission, just increases wear on the clutch. Whirlpool should have beefed up their clutches instead of shifting to a concept that is not only hit or miss but reduces performance while causing scum build up inside the machine. Here is a DD spin draining during the cool down and first spin, as I think all DDs should :) |
