Thread Number: 28081
Oasis/Cabrio owners |
Post# 429792 , Reply# 1   4/19/2010 at 03:44 (5,115 days old) by logixx (Germany)   |   | |
This is the AquaSmart - basically the same machine with some modifications. Note: you won't see at lot of turnover at regular playback speed, though. If you download them (say using flashload.net) and play them back at 2x or 3x the original speed, you'll see how even this load of towels turns over.
Alex |
Post# 429809 , Reply# 2   4/19/2010 at 05:59 (5,114 days old) by shanonabc ()   |   | |
Yay! My videos! :P |
Post# 429817 , Reply# 3   4/19/2010 at 07:18 (5,114 days old) by jasonl (Cookeville, TN)   |   | |
The aquasmart uses WAY more water than the Oasis does. I may have to make some more videos that show the water level at Normal, Sheets/Towels, and Bulky/Bedding cycle. |
Post# 429823 , Reply# 4   4/19/2010 at 07:38 (5,114 days old) by logixx (Germany)   |   | |
Also, the AquaSmart can be set to "Conventional Mode" (high water level) on practically all cycles. I'm actually surprised to see those towels being turned over so well on High Efficiency Mode - is was set to HE, wasn't it? I think the Cabrio defaults to a higher fill on Sheets/Towels.
This is on Conventional Mode |
