Thread Number: 28166
Bosch VT 596 Washer Dryer |
Post# 431410 , Reply# 1   4/26/2010 at 19:48 (5,084 days old) by Favorit ()   |   | |
otherwise it won't open (just like Mieles) Mieles have a safety mechanical latch release behind the cointrap lid, guess also BSH machines do a somewhat similar thing |
Post# 431499 , Reply# 2   4/27/2010 at 05:26 (5,084 days old) by retrohenna ()   |   | |
Thank you for your help! It is plugged in, but no joy. Will have another look now. |
Post# 431501 , Reply# 3   4/27/2010 at 05:56 (5,084 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Welcome to the club, Very much a classic washer dryer, solid and well made, try pushing the door fully shut, it could be half engaged against a sturdy rubber seal, check the fuse and if the power is working to the machine, also turn the programmer to the OFF position sometimes they wont open until the programmer is at the right setting etc..also remove the bottom panel, near where the pump filter is I`m sure there is a cord / lever to open the door in case of emergency..
Is this your machine?? |
Post# 431581 , Reply# 5   4/27/2010 at 12:26 (5,084 days old) by retrohenna ()   |   | |
And another picture: |
