Thread Number: 28213
Maytag Brake Package Removal Tool |
Post# 431590   4/27/2010 at 14:30 (5,111 days old) by scrubflex (bronx, new york)   |   | |
Does anyone have a brake removal tool to sell? |
Post# 431688 , Reply# 1   4/28/2010 at 07:53 (5,110 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 431798 , Reply# 3   4/28/2010 at 21:49 (5,109 days old) by scrubflex (bronx, new york)   |   | |
How exactly is this done? Even the service manual tells you to use the tool. |
Post# 431809 , Reply# 4   4/28/2010 at 23:02 (5,109 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
1 lay washer on side 2 remove belts and main drive pulley 3 remove 7/16"bolt and clip above brake package below base plate [very early washers had allen screw located in damper casting located above base plate that has to be removed instead of bolt and clip] 4 give threaded top of brake package a squirt of penetrating oil 5 take a blunt square chisel and place it against the side of one of the eight screws that hold the brake package together and hit it sharply with a hammer to loosen the brake assembly in a counter clockwise direction then finish removing by hand 6 if you have one of the newer brake packages that are crimped together [no screws] take a cold chisel and dig into the edge of the brake assembly creating a small dent or notch and loosen and unscrew 7 reassemble by hand giving a small tap with hammer in the same manner to tighten.
Post# 431810 , Reply# 5   4/28/2010 at 23:18 (5,109 days old) by dnastrau (Lords Valley, PA)   |   | |
Interesting - sounds do-able if you don't have the wrench. |
Post# 431820 , Reply# 7   4/29/2010 at 00:51 (5,109 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 431845 , Reply# 8   4/29/2010 at 07:33 (5,109 days old) by scrubflex (bronx, new york)   |   | |
Are you guys able to...rather can you post some demostration pics...I want to do it right. |
Post# 431858 , Reply# 9   4/29/2010 at 08:24 (5,109 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I did have the tool I threw it in the metal recycling bin years ago. Thats why I an taking the time to post all this . After doing it my way for years and then I finally found the special tool I was very disappointed the way it worked it tended to slip off the brake assembly so after using it a few times I never bothered again. Disassembling a MT washer this far is not something I would ever recommend any one attempt who is not pretty handy mechanically.
Post# 431878 , Reply# 10   4/29/2010 at 10:41 (5,109 days old) by dnastrau (Lords Valley, PA)   |   | |
I wonder if a large strap wrench might be helpful with this procedure as well... CLICK HERE TO GO TO dnastrau's LINK |
Post# 431903 , Reply# 11   4/29/2010 at 12:52 (5,109 days old) by scrubflex (bronx, new york)   |   | |
It would be harder to use "the without brake tool" method. I'd feel more secure...would need more input. |
Post# 431943 , Reply# 12   4/29/2010 at 14:54 (5,109 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 431993 , Reply# 13   4/29/2010 at 19:30 (5,108 days old) by surgilator_68 (Maryland)   |   | |
Post# 431994 , Reply# 14   4/29/2010 at 19:34 (5,108 days old) by bobbins (Victoria, BC, Canada)   |   | |
I have used an old pair of vice-grip and crimped the vice grip to the break package. Then I use a hammer on the vice-grip..usually works like a charm. The tool did work, but it often slipped off... Bob |
Post# 432138 , Reply# 15   4/30/2010 at 15:58 (5,108 days old) by scrubflex (bronx, new york)   |   | |
"...if one can't figure out how to unscrew...". not necessarily, I misunderstood the handling of the brake package. I thought I needed to be extra cautious with the brake because of the spring. It's about unscrewing and rescrewing the brake right and tight. |
Post# 432563 , Reply# 17   5/2/2010 at 20:35 (5,105 days old) by qsd-dan (West)   |   | |
Post# 432566 , Reply# 18   5/2/2010 at 20:45 (5,105 days old) by dnastrau (Lords Valley, PA)   |   | |
No problems! |
Post# 432886 , Reply# 19   5/3/2010 at 21:07 (5,104 days old) by scrubflex (bronx, new york)   |   | |
Soooooo, does anyone have an extra (Maytag Brake Assembly Removal Tool) they're willing to see me? |
Post# 432890 , Reply# 20   5/3/2010 at 21:23 (5,104 days old) by dnastrau (Lords Valley, PA)   |   | |
Here is about the cheapest I have seen one on the Internet... CLICK HERE TO GO TO dnastrau's LINK |
Post# 432895 , Reply# 21   5/3/2010 at 21:40 (5,104 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 432908 , Reply# 22   5/3/2010 at 22:34 (5,104 days old) by qsd-dan (West)   |   | |
Post# 432916 , Reply# 23   5/3/2010 at 23:55 (5,104 days old) by dnastrau (Lords Valley, PA)   |   | |
...and hopefully my luck won't run out yet! |
Post# 432969 , Reply# 24   5/4/2010 at 08:21 (5,104 days old) by scrubflex (bronx, new york)   |   | |
Dnastrau, it is the best price I've seen so far. |
Post# 432990 , Reply# 25   5/4/2010 at 09:27 (5,104 days old) by dnastrau (Lords Valley, PA)   |   | |
Someone else had mentioned finding one for $20 somewhat recently but they didn't post where it came from. A lot of places seem to want around $50 for them now. Andrew S. |
Post# 433025 , Reply# 26   5/4/2010 at 10:57 (5,104 days old) by scrubflex (bronx, new york)   |   | |
20$...I've never seen one for that price...yeah, $50-$60 is alot for using it once...hopefully they'll read the thread and remember where they seen the brake removal tool and post the site...thanks again, Andrew. |
Post# 433392 , Reply# 27   5/5/2010 at 21:29 (5,102 days old) by dnastrau (Lords Valley, PA)   |   | |
...courtesy of Oldschool on the board: CLICK HERE TO GO TO dnastrau's LINK |
Post# 433408 , Reply# 28   5/5/2010 at 22:19 (5,102 days old) by scrubflex (bronx, new york)   |   | |
That's AWESOME, thanks alot... I really appreciate that Andrew...That's amazing...I didn't think I'll find the tool at such a low price...really amazing...absolute GRATITUDE. Harry |
Post# 433413 , Reply# 29   5/5/2010 at 23:15 (5,102 days old) by dnastrau (Lords Valley, PA)   |   | |
...but Oldschool is the one to really thank! Hopefully that tool is still available. |
Post# 433606 , Reply# 30   5/6/2010 at 22:22 (5,101 days old) by scrubflex (bronx, new york)   |   | |
Thanks guys, I brought the brake removal tool this evening...it'll arrive in a few days. Dnastrau, thanks for remembering the low cost of the tool and Oldschool for the website to buy it from...THANKS A MILLION!!! Harry |
Post# 433661 , Reply# 31   5/7/2010 at 10:08 (5,101 days old) by dnastrau (Lords Valley, PA)   |   | |
Glad to help out! |
