Thread Number: 28226
Maytag, Alternate agitators for '74 A606 |
Post# 431719 , Reply# 1   4/28/2010 at 12:07 (5,103 days old) by PeterH770 (Marietta, GA)   |   | |
Nope. Just before the NorgeTags came out, they had an auger agitator for the orbital drive. It supposedly could sense the amount of clothes in the tub, and if it was loaded full, the auger would turn harder to push the load down.
The name of it is on the tip of my tongue, but won't come out! Must be having a senior moment... Guys here have put the Power Fin into an orbital drive machine, so reason says you should be able to put an Power Fin 12 or the auger agitator into a pitman transmission machine like yours. |
Post# 431722 , Reply# 2   4/28/2010 at 12:15 (5,103 days old) by swestoyz (Cedar Falls, IA)   |   | |
Pete: Load Sensor! :D
The Load Sensor or Power Flex 12 will fit just fine in your '06 machine. Just make sure it isn't the Load Sensor from the Norge based machines as you have pictured above. I don't have the PN on hand right now for the Orbital version..... Click the link below and scroll down. Somewhere in the thread I posted a YT video showing the differences between the original Power Fin and the Load Sensor. Check it out! Ben CLICK HERE TO GO TO swestoyz's LINK |
Post# 431782 , Reply# 3   4/28/2010 at 20:10 (5,102 days old) by dnastrau (Lords Valley, PA)   |   | |
I think this is a good used original... CLICK HERE TO GO TO dnastrau's LINK on eBay |
