Thread Number: 28312
DE806 operation and refurbishment... |
Post# 432923   5/4/2010 at 01:08 (5,104 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
It's been awhile, but Elginkid and I finally got our 1975 DE806 put back together and we have some issues and questions.
I finished reassembly, plugged the old girl in, and pushed Air Fluff (to test the motor without heat) and she purred quietly to life. I opened the door to turn it off and I found out I've got a bad door switch. There was not a way to stop the dryer! I ended up flipping off the circuit breaker to stop the dryer. I turned the dial to Regular and pushed the dial again. This time it came to life, heated as it should, burned off the dust from the element, and ran like a champ. How long should it run empty before shutting off? Ours went several minutes before we flipped the breaker off and called it a night. We are running it with a 3-prong plug. I did not connect a cabinet ground (might that explain the not shutting off?). Where is the cabinet ground screw anyway? 806 dryers are new to me, Dave |
Post# 432924 , Reply# 1   5/4/2010 at 01:16 (5,104 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Notice the shaft? It's thicker where it passes through the drum support bearing and is thinner after the plastic spacer where the blower wheel sits. It's amazing that this shaft bears the weight of the drum and its clothes without any rollers on the drum!
Oh yes, the shaft was well-lubed prior to reassembly. Also, the retaining ring that goes on the shaft on the back side of the drum support bearing can be a ROYAL PAIN to remove. We ended up bending ours out of shape so I went to Lowes to get a new one only to find out they don't carry them that big. Home Depot was worse in that they didn't carry them at all and the employees did not know what a retaining ring/snap ring was. I got one today at my local mom & pop hardware store. 5 minutes and 60 cents! |
Post# 432925 , Reply# 2   5/4/2010 at 01:19 (5,104 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Actually, he's oiling the drum support bearing prior to reinstalling the drum.
My question is: "Is the crazed look really necessary?" This post was last edited 05/04/2010 at 02:37 |
Post# 432926 , Reply# 3   5/4/2010 at 01:21 (5,104 days old) by spankomatic (Ukiah,CA)   |   | |
Seems like it should take about 10 min for the electronic control to "sense" the clothes are dry on any of the heated cycles. At that point the chime would sound "ding" and it would move on to the 10 min cool down part of the cycle. Air Fluff cycle is a pre-determined (I think 20 min) timed cycle.
Jim |
Post# 432927 , Reply# 4   5/4/2010 at 01:23 (5,104 days old) by qsd-dan (West)   |   | |
To test the electronic control unit, make sure the dryer is empty and select the "Damp Dry" setting. The machine should automatically turn off somewhere between 7-17 seconds.
The door switch for these machines have been NLA for a while, but they're still readily available. I don't have the part # handy with me right now, but if you go back to the post where I scanned the factory service manual, you'll find the part#. I believe there's a door switch right now on eBay for this machine. I have 5 or 6 electronic controlled HOH's (lost count) and never grounded any of them. They all function correctly. Who knows, maybe I'm lucky or these old girls know I saved their pretty tushes from the crusher and decide to behave ;) |
Post# 432928 , Reply# 5   5/4/2010 at 01:24 (5,104 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
This shot is looking through the drum support bearing. The metal sleeves (it's a sleeve bearing after all) at either end hold oil and sweat it out as it heats up from friction during operation. This film of sweated oil keeps things spinning smoothly and silently. The felt in the middle between the sleeves holds the oil. Yes, we oiled the felt quite a bit. It was interesting to watch the oil flow from the tube and onto the felt, sit there for a moment, and then get sucked into the felt.
We really oiled the heck out of this bearing. At one point I was oiling the bearing and this stuff started dripping out of it. "Hmmm" I thought to myself. "What is this stuff being displaced by oil in this bearing? I know! It must be the bearing's heck! I really am oiling the heck right out of this bearing!" For the record, heck closely resembles excess oil. Just remember that it's not excess oil, it's heck. Hopefully this bearing should be good for a few more decades of regular use. This post was last edited 05/04/2010 at 02:42 |
Post# 432929 , Reply# 6   5/4/2010 at 01:28 (5,104 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 432930 , Reply# 7   5/4/2010 at 01:28 (5,104 days old) by qsd-dan (West)   |   | |
Did you soak the wicking that sits between the drum bushing? That's critical for long term operation. I usually end up over oiling them and oil floats a wee over the wicking. It doesn't harm anything though.
Never mind, your post just popped up. Good Work!! This post was last edited 05/04/2010 at 01:31 |
Post# 432931 , Reply# 8   5/4/2010 at 01:30 (5,104 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 432932 , Reply# 9   5/4/2010 at 01:38 (5,104 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Note the new front felt seal glued in place with Maytag High Temperature Adhesive.
The dryer has been reassembled and tested but this is the last pic on my camera. I'll have to take off the cabinet again to replace the door switch though (aaaaaarrrrrrggggghhhhhhh!!!!!!!!!!). PS: We also oiled the bearing in the blower wheel and the idler pulley. I greased (not oiled) the slider that holds the idler pulley. I also put in new fiber washers in front of and behind the blower wheel. The blower runs great without any rubbing and the belt is perfectly aligned. This is one QUIET dryer. That's it for tonight, Dave This post was last edited 05/04/2010 at 01:39 |
Post# 432933 , Reply# 10   5/4/2010 at 01:42 (5,104 days old) by qsd-dan (West)   |   | |
Post# 432957 , Reply# 11   5/4/2010 at 06:50 (5,103 days old) by dnastrau (Lords Valley, PA)   |   | |
...and helpful pictures for anyone else who may be tackling this in the future. |
Post# 432968 , Reply# 12   5/4/2010 at 08:10 (5,103 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
All dryers gas or electric must be grounded not only for safety but if it has an electronic sensor control it may never shut off or at best work erratically. On electronic sensor dryers one of the sensor strips is grounded directly to the cabinet this is one reason the cabinet must be grounded. Normally on an electric dryer its grounded by a connection from the cabinet to the center post on the terminal block this provides a good ground through the three wire cord. This is often an aluminum strip on MT dryers brass or copper on other brands newer dryers usually use a green insulated wire that may be part of the wiring harness. You should always be sure this ground is in place or another good ground is attached to the appliance before you even think of plugging it in, this also goes for old washers stoves etc. I think when Dan said he didn't ground any of his dryers he was talking about an auxiliary ground wire. MT left a screw connection on the back of thier dryers for a separate ground wire which is not required is most areas although its never a bad idea to be double safe.
Post# 433004 , Reply# 13   5/4/2010 at 10:02 (5,103 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 433054 , Reply# 14   5/4/2010 at 13:29 (5,103 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Umm... I just happened to know a "certain" avocado green GE V-16 dryer that is VERY close, if not tied - or just ahead of the HOH. I think you saw it and heard it Dan! Ducks & runs? LOL OK, seriously, yes they are incredibly quiet dryers! Question: Is the 806 supposed to have a "cool down" period, on the regular cycle, prior to shutting off?? My 1970 H-gold DE806 doesn't seem to. When it chimes, it stops immediately and the clothes inside are still very hot! (tho I also noticed the '70 GE V-16 is too) I also have a newer DG808 and (I'm pretty sure) it chimes once (at cool down?) and then again when it shuts off. Thanks! Kevin This post was last edited 05/04/2010 at 13:36 |
Post# 433114 , Reply# 15   5/4/2010 at 18:43 (5,103 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 433117 , Reply# 16   5/4/2010 at 19:00 (5,103 days old) by qsd-dan (West)   |   | |
Yeah, the GE was pretty darn quiet too. It's shame I didn't have a refurbished HOH handy at the time for a side-by side comparison with my DB meter. My 1970 H-gold DE806 doesn't seem to. When it chimes, it stops immediately and the clothes inside are still very hot! (tho I also noticed the '70 GE V-16 is too) I also have a newer DG808 and (I'm pretty sure) it chimes once (at cool down?) and then again when it shuts off. The DE806 should run a couple of minutes after the chime sounds, before stopping. If it doesn't, you have a bad cool down thermostat. Usually the cool down thermos fail in the other direction and the machine never shuts off after the chime. The 606/806/906 machines had a relatively short cool down cycle. Usually it was around 2 minutes or so. However, I just select "Air Dry" right after the first chime as a poor mans "Wrinkle Guard" for the shirts and it'll turn off at about the 10 minute mark. |
Post# 433145 , Reply# 17   5/4/2010 at 21:43 (5,103 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
If I remember correctly the MT cool down thermostat is 125F so on damp dry the dryer doesn't even reach that temp so the dryer stops when the sensor trips the bell and the solenoid is activated. On reg dry the control stops the dryer with a little moisture left in the load so with the continued evaporation taking place the thermostat resets fairly quickly resulting a fairly short cool down. On PP the clothes get dryer and hotter resulting in the longest cool down. But a lot depends on the room temp where the dryer is located. I had one customer that installed an adjustable thermostat calibrated in degrees so he could set it about 20F above room temp and get a nice long cool down. You could of corse just install a cooler fixed thromostat but if the room temp was too high the dryer may never stop. I remember we had a DE606 that was installed in a hot boiler room and they complained that it often would't stop maytag sent us a hotter thermostat for that machine.
Post# 433167 , Reply# 18   5/5/2010 at 00:46 (5,103 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
You REALLY have to take this dryer apart to change out the door switch! This is inside the cabinet after I took out the heater. The offending door switch is visible at the upper right of the door. The hinge is sandwiched between the cabinet and the switch. Also note that someone at the Maytag factory wrote 806 above the door. This was covered by the heater and I had no idea it was there before.
The old door switch had a date stamped on it of 1973. We think the dryer is a 1975. Were they just using up an old stock of switches? |
Post# 433169 , Reply# 19   5/5/2010 at 00:49 (5,103 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 433170 , Reply# 20   5/5/2010 at 00:52 (5,103 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 433171 , Reply# 21   5/5/2010 at 00:55 (5,103 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 433172 , Reply# 22   5/5/2010 at 00:57 (5,103 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 433226 , Reply# 23   5/5/2010 at 06:59 (5,102 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Dave great looking pair with the lights on, one thing I always think about doing with one of my MT 806 style pairs is to install longer florescent bulbs in the panels for more even lighting across the full width of the control panel. As I restore my A900 pair I my even try to custom taylor some LED lighting strips into the console as long as it looks authentic it might be fun to see how even a look I can get.
Post# 433232 , Reply# 24   5/5/2010 at 07:21 (5,102 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
You and Wes did a great job, CONGRATS!! Plus they look fantastic too! Kevin P.S. Thank you for the 806 cool down info Dan!! This post was last edited 05/05/2010 at 07:22 |
Post# 433284 , Reply# 25   5/5/2010 at 10:42 (5,102 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 433460 , Reply# 26   5/6/2010 at 10:19 (5,101 days old) by mistereric (New Jersey (Taylor Ham))   |   | |
Post# 433478 , Reply# 27   5/6/2010 at 11:54 (5,101 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
