Thread Number: 28328
Parts that have to go |
Post# 433341 , Reply# 1   5/5/2010 at 13:46 (5,097 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 433364 , Reply# 2   5/5/2010 at 17:21 (5,096 days old) by supremewhirlpol ()   |   | |
The FF dispenser and pan have been spoken for. Here are pictures of the caps. |
Post# 433366 , Reply# 3   5/5/2010 at 17:22 (5,096 days old) by supremewhirlpol ()   |   | |
The DW motor |
Post# 433367 , Reply# 4   5/5/2010 at 17:25 (5,096 days old) by supremewhirlpol ()   |   | |
This SQ/Amana/Maytag motor assembly has to go too. |
Post# 433368 , Reply# 5   5/5/2010 at 17:27 (5,096 days old) by supremewhirlpol ()   |   | |
Maytag squirrel cage (new in box) |
Post# 433369 , Reply# 6   5/5/2010 at 17:29 (5,096 days old) by supremewhirlpol ()   |   | |
The westinghouse FL motor/pump (packed in box) |
Post# 433370 , Reply# 7   5/5/2010 at 17:30 (5,096 days old) by supremewhirlpol ()   |   | |
The timers |
Post# 433371 , Reply# 8   5/5/2010 at 17:35 (5,096 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 433372 , Reply# 9   5/5/2010 at 17:39 (5,096 days old) by supremewhirlpol ()   |   | |
The parts are free. If shipping is necessary, you pay for that. |
Post# 433423 , Reply# 10   5/6/2010 at 00:15 (5,096 days old) by markk290 ()   |   | |
You don't happened to have this timer:374172. This is still available thru repair clinic, but hopping to save some money. This fits my 76 lady kenmore. |
Post# 433427 , Reply# 11   5/6/2010 at 00:57 (5,096 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Mark -
If he doesn't have it, there are bunches of them on ebay in the 20-dollar range, including shipping. Search part 660693, which is the universal replacement for your timer. Odd thing is, if you were to get a new timer, the box would say 660693, but the timer itself very well may say '374172' on it. GOOD LUCK! Gordon |
Post# 433429 , Reply# 12   5/6/2010 at 01:37 (5,096 days old) by supremewhirlpol ()   |   | |
markk290: The only timers that I have for BD machines are listed above. Gordon: The timers are yours. I sent you an email. |
Post# 433444 , Reply# 13   5/6/2010 at 06:10 (5,096 days old) by markk290 ()   |   | |
Gordon and Melvin thanks for the information. Mark |
Post# 433559 , Reply# 14   5/6/2010 at 18:57 (5,095 days old) by supremewhirlpol ()   |   | |
More BD stuff have to go. Here is a GE FF 4 port pump. |
Post# 433560 , Reply# 15   5/6/2010 at 18:59 (5,095 days old) by supremewhirlpol ()   |   | |
Some sort of hose: FSP P/N: 62731 JY |
Post# 433561 , Reply# 16   5/6/2010 at 19:01 (5,095 days old) by supremewhirlpol ()   |   | |
Another hose FSP P/N:386929 LD |
Post# 433562 , Reply# 17   5/6/2010 at 19:04 (5,095 days old) by supremewhirlpol ()   |   | |
Hose off BD machine P/N: 21114 with drain connector P/N: wc6 95440 |
Post# 433563 , Reply# 18   5/6/2010 at 19:06 (5,095 days old) by supremewhirlpol ()   |   | |
Small hose P/N: 3349365-ADN |
Post# 433564 , Reply# 19   5/6/2010 at 19:08 (5,095 days old) by supremewhirlpol ()   |   | |
Whirlpool timer harness with PS and SW |
Post# 433565 , Reply# 20   5/6/2010 at 19:10 (5,095 days old) by supremewhirlpol ()   |   | |
Whirlpool timer harness with push switches, and PS along with another timer harness |
Post# 433568 , Reply# 21   5/6/2010 at 19:17 (5,095 days old) by supremewhirlpol ()   |   | |
Hose: P/N: 358560 LD with drain connector P/N: wc1 95440 |
Post# 433572 , Reply# 22   5/6/2010 at 19:19 (5,095 days old) by supremewhirlpol ()   |   | |
valves with splash guard water vent |
Post# 433573 , Reply# 23   5/6/2010 at 19:20 (5,095 days old) by supremewhirlpol ()   |   | |
Hose FSP P/N: 386933 JY |
Post# 433574 , Reply# 24   5/6/2010 at 19:22 (5,095 days old) by supremewhirlpol ()   |   | |
markk290: no more BD timers in the house, will check in the shed tomorrow. I also have Calypso parts that I will post tomorrow. |
Post# 433668 , Reply# 25   5/7/2010 at 10:32 (5,095 days old) by rollermatic (cincinnati)   |   | |
Post# 433743 , Reply# 26   5/7/2010 at 16:16 (5,094 days old) by supremewhirlpol ()   |   | |
Gordon: I shipped the timers off before I saw your email. I will send the hoses separately. |
Post# 433752 , Reply# 27   5/7/2010 at 17:25 (5,094 days old) by supremewhirlpol ()   |   | |
I went through the shed and I have both Neptune FL and Calypso parts. I will post them shortly. |
Post# 433779 , Reply# 28   5/7/2010 at 20:24 (5,094 days old) by supremewhirlpol ()   |   | |
Here is a recirculation pump/motor from a Calypso machine. Motor P/N: 8054968 pump P/N: 8527772 |
Post# 433780 , Reply# 29   5/7/2010 at 20:28 (5,094 days old) by supremewhirlpol ()   |   | |
Calypso Drain hose |
Post# 433781 , Reply# 30   5/7/2010 at 20:31 (5,094 days old) by supremewhirlpol ()   |   | |
calypso Wire harness with pressure switch PS P/N: 8054766 |
Post# 433782 , Reply# 31   5/7/2010 at 20:34 (5,094 days old) by supremewhirlpol ()   |   | |
Timer for Maytag Neptune I think. Neptune was junked because of bearing failure and the shaft was ruined. P/N: 2714060 |
Post# 433783 , Reply# 32   5/7/2010 at 20:36 (5,094 days old) by supremewhirlpol ()   |   | |
Calypso shaft assembly with pulley and belt |
Post# 433784 , Reply# 33   5/7/2010 at 20:37 (5,094 days old) by supremewhirlpol ()   |   | |
The spline has seen better days! |
Post# 433786 , Reply# 34   5/7/2010 at 20:39 (5,094 days old) by supremewhirlpol ()   |   | |
Calypso water valves |
Post# 433787 , Reply# 35   5/7/2010 at 20:40 (5,094 days old) by supremewhirlpol ()   |   | |
Calypso Shocks |
Post# 433788 , Reply# 36   5/7/2010 at 20:41 (5,094 days old) by supremewhirlpol ()   |   | |
Calypso drain hose holder |
Post# 433789 , Reply# 37   5/7/2010 at 20:43 (5,094 days old) by supremewhirlpol ()   |   | |
Another calypso pump, but the motor was bad. |
Post# 433791 , Reply# 38   5/7/2010 at 20:45 (5,094 days old) by supremewhirlpol ()   |   | |
Calypso flood switch |
Post# 433792 , Reply# 39   5/7/2010 at 20:46 (5,094 days old) by supremewhirlpol ()   |   | |
Calypso line filter |
Post# 433793 , Reply# 40   5/7/2010 at 20:49 (5,094 days old) by supremewhirlpol ()   |   | |
Neptune switches, recirculation pump motor capacitor, calypso motor bracket |
Post# 433794 , Reply# 41   5/7/2010 at 20:51 (5,094 days old) by supremewhirlpol ()   |   | |
Calypso lid switch, other hoses, feet and A spring that I don't remember what machine it goes to. |
Post# 433795 , Reply# 42   5/7/2010 at 20:53 (5,094 days old) by supremewhirlpol ()   |   | |
Tomorrow I will post the Calypso drive motor, control board, and wire harness. |
Post# 433972 , Reply# 43   5/8/2010 at 17:24 (5,093 days old) by supremewhirlpol ()   |   | |
Calypso motor control board |
Post# 433973 , Reply# 44   5/8/2010 at 17:26 (5,093 days old) by supremewhirlpol ()   |   | |
Calypso motor |
Post# 433974 , Reply# 45   5/8/2010 at 17:28 (5,093 days old) by supremewhirlpol ()   |   | |
Calypso wire harness with ground switches |
Post# 433975 , Reply# 46   5/8/2010 at 17:30 (5,093 days old) by supremewhirlpol ()   |   | |
More Neptune switches |
Post# 435640 , Reply# 49   5/16/2010 at 19:27 (5,085 days old) by coldspot66 (Plymouth, Mass)   |   | |
Do you have a part # for the Westy f/l motor/pump. Is it new? |
Post# 435648 , Reply# 50   5/16/2010 at 20:16 (5,085 days old) by supremewhirlpol ()   |   | |
coldspot66: The motor and pump are used and I don't have a part number. here are more pictures |
Post# 435649 , Reply# 51   5/16/2010 at 20:18 (5,085 days old) by supremewhirlpol ()   |   | |
3 port pump |
Post# 435650 , Reply# 52   5/16/2010 at 20:19 (5,085 days old) by supremewhirlpol ()   |   | |
another |
Post# 435651 , Reply# 53   5/16/2010 at 20:20 (5,085 days old) by supremewhirlpol ()   |   | |
another |
Post# 435653 , Reply# 54   5/16/2010 at 20:21 (5,085 days old) by supremewhirlpol ()   |   | |
Motor has 3 terminals and is 1725 RPM only |
Post# 824111 , Reply# 55   5/19/2015 at 06:20 (3,257 days old) by oscarmsiller ()   |   | |
Hi, I need the recirculation pump/motor from a Calypso machine. Motor P/N: 8054968 pump P/N: 8527772 Price $$$ ??????? thanks |
Post# 824118 , Reply# 56   5/19/2015 at 06:54 (3,257 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 824122 , Reply# 57   5/19/2015 at 07:42 (3,257 days old) by mayken4now (Panama City, Florida)   |   | |
Post# 824278 , Reply# 58   5/20/2015 at 04:27 (3,256 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
