Thread Number: 2835
Mystery "spacer" for Unimatic transmission-------------------- |
Post# 76009 , Reply# 1   8/1/2005 at 13:02 (6,814 days old) by Gyrafoam (Wytheville, VA)   |   | |
Sorry folks, the download seemed to "take" when I was creating the thread, but somehow failed to attach to it. I used the "Upload JPEG or GIF Format Picture to share" box, but must be doing something incorrectly. |
Post# 76011 , Reply# 2   8/1/2005 at 13:10 (6,814 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 76016 , Reply# 3   8/1/2005 at 14:06 (6,814 days old) by Unimatic1140 (Minneapolis)   |   | |
Hi Steve, first of all the picture you sent me in my email is only 49K so it is plenty small and easily uploaded as you can see... That spacer slips over the spin shaft first, before you screw the seal assembly onto the top of the mechanism. The bushing will sit right on top of that spacer. Please use this thread to practice loading some pictures, it really is very easy. You should see the picture in your preview if it is going to load. By the way did you replace the spin bearing that is located at the top of the mechanism housing? There is nothing worse than getting everything back together and finding out that it works perfectly except for a loud screaming spin cycle. I speak from experience with that :) |
Post# 76017 , Reply# 4   8/1/2005 at 14:10 (6,814 days old) by Unimatic1140 (Minneapolis)   |   | |
Be advised Steve, one thing I just thought of is that extra spacer does not come with that seal kit and someone might have put it in the box by accident. There is a chance that the spacer is already installed on the spin shaft. The spacer should sit right on top of the spin bearing. If there already is one in there don't use two, that will make for a very bad seal and the tub will be too high.
Post# 76044 , Reply# 7   8/1/2005 at 18:15 (6,814 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
