Thread Number: 28663
Plastic parts suck--- |
Post# 437612   5/26/2010 at 13:41 (5,083 days old) by laundromat (Hilo, Hawaii)   |   | |
I have 4 Frigidaire front loaders. Three are Affinities and one is a FriGEMore with the rectangular door. They all have plastic mixiing inlet valves. The problem is that:
A.the threaded stems are too close together making it difficult to connect and/or disconnect the hoses. B.because it's plastic,the threading strips so easily that you have to be real delicate on the instalation. I disconnected the red model to stack the dryer on top. As I went to reconnect it,the damned thing stripped the threading and I had to rethread it.What a PITA! |
Post# 437682 , Reply# 2   5/26/2010 at 19:55 (5,082 days old) by aaronfitzy (Pennsylvania)   |   | |
Post# 437694 , Reply# 3   5/26/2010 at 20:40 (5,082 days old) by Maytagbear (N.E. Ohio)   |   | |
is made by Electrolux-Frigidaire. Lawrence/Maytagbear |
Post# 437830 , Reply# 4   5/27/2010 at 12:05 (5,082 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 437902 , Reply# 5   5/27/2010 at 16:12 (5,081 days old) by aaronfitzy (Pennsylvania)   |   | |
Post# 437921 , Reply# 6   5/27/2010 at 18:21 (5,081 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Inlet valves have been plastic since the mid 1950s, there should be no problems with stripped threads. To install a hose screw it on by hand until finger tight then tighten with flyers an additional 1/2 to 1 full turn. If you can't screw it on by hand get a new hose, if it still leaks after tightening install a new hose washer or replace the hose. We have started using the new nylon reinforced hoses WP is selling I like them much better than the SS reinforced hoses. They have a larger inside diameter for better water flow and your not sending so much money to China for the nickel that is used to make the SS.
Post# 437947 , Reply# 7   5/27/2010 at 21:33 (5,081 days old) by mark_wpduet (Lexington KY)   |   | |
