Thread Number: 28775
Hoover Keymatic door seal |
Post# 439022   6/2/2010 at 05:24 (5,076 days old) by turnamat (Germany)   |   | |
Hello@all!
I´m searching for a new door seal for a good working Keymatic from the early 60ies.Not possible to get it in germany,cause the machines have not been popular here,and only a few are found on eBay,mostly in worse condition!Hopefully,I´ll get some information about where to get one here! Thomas. |
Post# 439024 , Reply# 1   6/2/2010 at 05:42 (5,076 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Morning Thomas
Dont hold your breath on that one, the door boots for the sloping front (am assuming its the sloping front) keymatic are virtually non existant!!! we are slowly working our way through new spares, mainly old Euro models to see if one will be suitable. What model is yours?? any pics?? Failing that we just may have to find a place to have some manufacturerd, as between us all there appears to be a growing number of keymatics surfacing which would help with the costs!! |
Post# 439029 , Reply# 2   6/2/2010 at 06:05 (5,076 days old) by turnamat (Germany)   |   | |
Post# 439031 , Reply# 3   6/2/2010 at 06:19 (5,076 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Nice one Thomas, its the first Hoover model 3224 with timeline, and a lovely original turquoise door boot!!!
The only thing you could experiment with is to paint onto the rubber a clear sealant etc and build it up in layers, I`ll tell you now that type of rubber just turns to mush when you start to remove it!! so take plenty of pictures before you attempt to move it!!! Does it work and complete a wash etc?? |
Post# 439033 , Reply# 4   6/2/2010 at 06:27 (5,076 days old) by turnamat (Germany)   |   | |
Post# 439099 , Reply# 5   6/2/2010 at 12:11 (5,076 days old) by hotpoint9534 (UK)   |   | |
The best option would be to get a batch specially produced before the last existing one turns to mush. If enough were produced the cost per unit wouldn't be too great. Tom. |
Post# 439271 , Reply# 8   6/2/2010 at 21:31 (5,075 days old) by turnamat (Germany)   |   | |
Post# 439282 , Reply# 10   6/2/2010 at 21:58 (5,075 days old) by A440 ()   |   | |
I meant to say "Keymatic" not "Kaymatic". Although I think the "Hoover Kaymatic" would be kind of festive! |
Post# 439283 , Reply# 11   6/2/2010 at 22:01 (5,075 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 439321 , Reply# 12   6/3/2010 at 00:18 (5,075 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 439334 , Reply# 13   6/3/2010 at 03:50 (5,075 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
The issue with the Keymatic is as Louis says, its small at the point of opening on the cabinet, under 30cm, but the drum opening has a much bigger opening!!!
THEN, look at Thomas`s pic when empty, it looks level, BUT as the drum fill and drops back, the boot opens up CONSIDERABLY, and thats the problem, small front, large behind and needs a lot of slack in the middle!!! Brent, good thinking about the Dreamspace/Duet, tried that one, much too big on the front cabinet opening and not enough slack!! Hey Jon, you didnt say you`d gone direct!! Paul, Tania & team know us very well, I`ve a stash of defunct boots from machines of bygone times where we are trying to find one to fit...LOL..what happened to the 2 packages of boots that I sent?? where they for different Bendixii?? |
Post# 439336 , Reply# 14   6/3/2010 at 03:59 (5,075 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 439337 , Reply# 15   6/3/2010 at 04:04 (5,075 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Post# 439352 , Reply# 16   6/3/2010 at 06:59 (5,075 days old) by dnastrau (Lords Valley, PA)   |   | |
"Matchboxpaul" has a post 236257 on this old thread where someone used a different boot (Hoover New Wave) on a Keymatic. Perhaps this will help. CLICK HERE TO GO TO dnastrau's LINK |
Post# 439358 , Reply# 17   6/3/2010 at 07:37 (5,075 days old) by vacbear58 (Sutton In Ashfield, East Midlands, UK)   |   | |
I suspect that the machine being referred to in the old thread is the one pictured above, and which appeared in our recent threads of our last get together in Chester.
One one thought which strikes me is what about the door boot used on the old slant front Westinghouse models. From what I have learned (on here) the two machines operate on a similar principle of the drum changing angle as it fills with water, so if the dimesnions were right ..... I realise that these must be pretty rare too and even older than the Keymatic but perhaps rather more plentiful? Al |
Post# 439360 , Reply# 18   6/3/2010 at 07:49 (5,075 days old) by turnamat (Germany)   |   | |
Thanx alot for all the good news!
I sent an eMail to Paul Curran,maybe there will be one still existing! Please hold Your thumbs for me,would be the luckiest man in the world having a complete wash with no leaking in my keymatic! Then,I would have both of my dream machines work perfect:The Hoovermatic that is still running well and-hopefully-the Keymatic! Thanx to All of You, Thomas. |
Post# 439373 , Reply# 19   6/3/2010 at 08:43 (5,075 days old) by chestermikeuk (Rainhill *Home of the RailwayTrials* Merseyside,UK)   |   | |
Hi Andrew
Yes Mathew (keymatic3203) used a new-wave boot to cover the base of the tub whilst he tested out the machine, the boot wouldnt fit around the top of the tub/cabinet opening so unfortunately is not a total fit!!! Heres mine after finding a NIB black replacement boot and giving up the lovely turquoise!!! We`ll keep looking!! |
Post# 439374 , Reply# 20   6/3/2010 at 08:57 (5,075 days old) by turnamat (Germany)   |   | |
Post# 439487 , Reply# 21   6/3/2010 at 18:58 (5,074 days old) by dnastrau (Lords Valley, PA)   |   | |
Too bad that the other boot won't work. I hope you find the correct replacement! |
Post# 439500 , Reply# 22   6/3/2010 at 20:24 (5,074 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
