Thread Number: 28883
LG Tromm discharge hose replacement |
Post# 440333   6/8/2010 at 11:00 (5,064 days old) by drhardee ( Columbia, SC)   |   | |
A friend of mine needs to replace the discharge (drain) hose on his LG Tromm FL washer. Apparently, the hose is accessible from the bottom of the washer. The owner's manual says to call a technician to replace the hose. Is this something that a reasonably skilled D-I-Y'er can do? Any assistance would be appreciated. Let me know if you require a model number for further assistance. Thanks!
Post# 441358 , Reply# 2   6/13/2010 at 19:25 (5,059 days old) by yogitunes (New Jersey)   |   | |
a D-I-Yer should be able to rig it up....I did it one time to a top console model, a combination of a piece of hose connected to the pump, and then a few pieces of plastic pipe in a bit of a "S" turn to end up with a port out the back of the machine, and then attach a regular generic drain hose for what is needed....you may even have some of this stuff arond the house...plastic pipe, a few fittings and some glue works wonders in many applications
I got all this stuff at Lowes....a lot cheaper than buying the original hose post a few pics if you need some help let us know how you made out |
