Thread Number: 28889
Whirlpool Duet Dryer Problem |
Post# 440486   6/8/2010 at 21:37 (5,064 days old) by Spankomatic (Ukiah,CA)   |   | |
Post# 440495 , Reply# 1   6/8/2010 at 21:56 (5,064 days old) by nmassman44 (Brooksville Florida)   |   | |
According to the service manual an E1 code means an open thermistor or wire harness...
THERMISTOR Refer to page 4-7 for the procedure for servic- ing the thermistor. The thermistor monitors the exhaust temper- ature and cycles the high-limit thermostat on and off to maintain the desired temperature. 1. Turn the dryer off but keep the electrical supply connected. 2. Make sure that the dryer is empty and that the lint screen is clean. 3. Close the dryer door. 4. Select Heavy Duty, Timed Dry, More Time or Less Time, End of Cycle Signal (Louder) and Start. 5. If error codes E1 or E2 flash on the dis- play after 1 minute and the dryer turns off, the thermistor, or the wire harness, is ei- ther shorted or open. Check the wire con- nections at the thermistor or the machine control electronics board. If wiring checks okay, replace the thermistor. 6. If the dryer seems to operate normally, re- move the exhaust vent and start the dryer. 7. Select the desired temperature cycle to be tested, and select 20 minutes of Timed Dry heat using the More Time or Less Time pushbuttons. 8. Hold a glass bulb thermometer capable of reading from 32°C to 82°C (90° to 180°F) in the center of the exhaust outlet. Mea- sure the exhaust temperatures with the heater on and off. The correct exhaust tem- peratures for the various settings are shown in the following chart. 9. If the exhaust temperature is not within the specified limits, check the resistance of the thermistor, as shown in the following chart. If the resistance is okay, replace the ma- chine control electronics board. TEMP RESISTANCE TEMP RESISTANCE °C (°F) (K Ω ) °C (°F) (K Ω ) 10° (50°) 19.9 43° (110°) 4.7 16° (60°) 15.3 49° (120°) 3.7 21° (70°) 11.9 54° (130°) 3.1 27° (80°) 9.2 60° (140°) 2.5 32° (90°) 7.4 66° (150°) 2.1 38° (100°) 5.7 71° (160°) 1.7 THERMISTOR RESISTANCE TEMPERATURE HEAT TURNS HEAT TURNS SETTING OFF ON 68° C ±6° (155° F ±10°) MEDIUM 66° C ±6° 6 - 8° C HIGH (150° F ±10°) (10 - 15° F) 60° C ±6° below the heat (140° F ±10°) turn off 52° C ±6° temperature (125° F ±10°) EXTRA 41° C ±3° LOW (105° F ±5°) HIGH MEDIUM LOW |
Post# 440731 , Reply# 2   6/10/2010 at 02:18 (5,062 days old) by Spankomatic (Ukiah,CA)   |   | |
Post# 440732 , Reply# 3   6/10/2010 at 02:18 (5,062 days old) by Spankomatic (Ukiah,CA)   |   | |
Post# 440834 , Reply# 4   6/10/2010 at 17:30 (5,062 days old) by mark_wpduet (Lexington KY)   |   | |
