Thread Number: 29015
Avocado Kenmores with a new home |
Post# 442014 , Reply# 1   6/15/2010 at 22:20 (5,055 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
When you get these Bautys i would love to see some close up pic of the washer including some closeup of the control panel timer knob and the inside if its possible and a video of the washer going through a full cycle Please and if you want a good tip to keep these beautys mint and rust free after each cycles wipe the tub dry with a dry towel and keep the lid open until the tub and agitator are fully dry.
Pierre |
Post# 442121 , Reply# 4   6/16/2010 at 11:43 (5,054 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Rob -
The bleach dispensers were always colored the match the top. At least in that version. BUT, replacements are white only. The Roto-swirl went white with the 1976 models but the Straight Vane didn't until very late in the 24-inch machine production (1983-ish) and I've only ever seen one in white. There are 'gradients' in wash-basket coloring that Sears never made a big deal about. I don't think WP did that at all, but for many years, entry-level BOL Kenmores had a blue, non-speckled porcelain tub. That coupled with a black agitator made for a very dark looking machine inside. Next up was the blue speckle, or as WP currently calls it "Spreckle". The speckle changed to a light-blue or beige in upper 70-series and higher machines. I think it has to do with heavier coatings of protective finish. Yours is a 70 series, and is the only 1977 70 model in standard capacity. The 60 series (manual filter, straight vane, no pre-wash) had the blue speckle. Beyond the light colored basket, some TOL machines at times had a full white basket like those of the 1960s. The 72 and 74 Lady Ks come to mind on that. Later, the all-blue BOL tub was dropped, as was the TOL all-white, and we just had the two varying degrees of speckle. In the mid80s, the all-white basket came back and was in one 1983 model the ONLY difference between it and the machine before it. A "Two-fire" white basket they called it. It's hard to predict what model crossed the threshold on getting the light colored basket, but it's usually somewhere between 70 series and 80 series. I have two interesting examples: In 1977 Kenmore offered a 70 series Large Cap. washer with 5 cycles, three levels, three temps, and a Penta-Swirl. It had an off-balance relay and a porcelain top. It was known as a 27701. It had the beige tub as did the 76 70-series. There was one other 70 in 1977 - the 27741. Usually, as stock numbers go up, the machine gets better. Not in this case. The 27741 has no porcelain top, no relay, and a blue speckled tub. In 1979, this same scenario was put into production, and done again in the 80-series line. The first 80 series was a 29801, four levels, three temps, five cycles, Penta-Swirl, porcelain top, beige basket. The 29811 added a DA agitator. The 29821 added another water level, two more temps, and two dispensers. The 29831 though, dropped to three levels, three temps, no porcelain top (just a porcelain lid), and a blue speckled basket. Oddly, I have seen more 29831s than all the 801s, 811s, and 821s put together. I think both the 27741 and the 29831 were designed to be price-point marketing machines, and they sold the crud out of them. Gordon This post was last edited 06/16/2010 at 13:54 |
Post# 442204 , Reply# 5   6/16/2010 at 16:03 (5,054 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 442364 , Reply# 8   6/16/2010 at 23:33 (5,054 days old) by rll70sman (Hastings, Minnesota)   |   | |
It may be the drive pulley. The noise is kind of a "sh, sh, sh" if that makes sense. Otherwise, I love how the pump "breathes" after all the water is drained from the tub. It seemed like all the older Kenmores and Whirlpools did that. |
Post# 442401 , Reply# 9   6/17/2010 at 07:27 (5,053 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The spin pulley bearing could be worn or very dry. If this is the case it will be noisy when agitating or draining but the noise will go away completely when the basket reaches full spin speed as the spin pulley and spin tube are now turning together at the same speed. There are several items that should be looked at and oiled or other wise serviced on a 30 year old washer if you want to use it as an everyday machine. By giving it a light overhaul now you can avoid doing major repairs later. It would probably best to talk to someone like Gordon or myself about how to proceed with a major servicing, Good luck with your new washer.
Post# 442479 , Reply# 11   6/17/2010 at 12:40 (5,053 days old) by rll70sman (Hastings, Minnesota)   |   | |
John, your and Gordon's help would be greatly appreciated. Please contact me offline. Thanks! Rob |
Post# 442504 , Reply# 12   6/17/2010 at 14:47 (5,053 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
Rob -
I have some videos on YouTube too that you may want to check. My camera stinks, but the sound is good and if any of my machines sound like yours, that would be a big help for me to know what your noise is, unless you can video it. There are four pulleys moving on a belt-drive, the motor, the basket drive, the pump, and the transmission drive pulley. The motor's pulley won't make any noise itself I don't think unless it's loose or mis-aligned, but the motor itself can insert some noise in a BD machine, usually a louder hum when the motor's bearings wear. Standard capacity machines often had a light gray painted GE motor, not to offend any GE fans, but I never liked those motors as they were often loud. The transmission drive pulley doesn't usually transmit transmission noises that I'm aware of, but due to the size of the pulley, if the belt is making any stretching sounds, and some do, the pulley will amplifiy them like a sound plate. Several of my machines do that and if you know what you're listening to, you can hear them in my videos. It's like a 'swish-swish-swish' sound and it's worst in agitate, and mostly goes away when the machine is under little load as in neutral drain. This noise is nothing to be concerned about. A pump can make a number of sounds, and it can be isolated simply by the fact that the pump is always turning when the machine runs, so if the noise never goes away, look there first. The basket drive, just as John said, can be a noise maker. The pulley on a basket drive also always turns, but in everything but spin, the pulley is rotating on the spin tube. There is only a sleeve bearing in between the two, and if that wears a little, the pulley can make a rat-a-tat-tat sound that remains all through wash, and only goes away in spin when the pulley and the spin tube are moving together. The noise will often be gone in rinse agitation because the first spin generates enough friction heat to warm up the parts and make the gaps narrow enough to stop the noise. I have heard this noise in lots of belt drives, and its probably the most annoying because it interferes with the 'harmony' of the machine's sound. It's a beetch to get rid of though, so if your noise is stopping within moments after the machine goes into spin, I suggest you either get used to it, or prepare to do some basket drive work. The belt in your machine may very well be beyond it's prime, especially if it's original. They dry out, become a little more brittle, and like old automotive tires, they transmit lots more noise and vibration than a supple, new belt. I think I'd practice belt replacement on the 24-inch machine vs. experimenting on this nice machine if I were you Rob, but you CAN change the belt. Sometimes when the parts are loosened to change a belt, everything makes more noise when it goes back together, so you may want to keep that in mind. If you can record the sound, I bet I can tell you what it is. Gordon |
Post# 444192 , Reply# 14   6/24/2010 at 17:35 (5,046 days old) by Tinkernut8 ()   |   | |
Congratulations Rob, I’m sure you’ll get 30 more years out of those avocado gems!! Great find. |
Post# 444310 , Reply# 15   6/25/2010 at 03:39 (5,046 days old) by aldspinboy (Philadelphia, Pa)   |   | |
