Thread Number: 29088
Calling on Kenmore Front Loading experts( HE 3t) from around 2002-2004 |
Post# 442961   6/19/2010 at 20:54 (5,057 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 443052 , Reply# 1   6/20/2010 at 04:10 (5,057 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 443071 , Reply# 2   6/20/2010 at 08:30 (5,057 days old) by surgilator_68 (Maryland)   |   | |
I think it's broken. Yes, that's it!! It's broken!
Do the lights light up? Do ALL of the buttons respond when pressed? If the answer is yes to those questions it will most likely need a Central Control Unit. However before I go that far I would check all the connections on the door lock and all the connections on the CCU and MCU. Don't just look at them, pull each one off, look at the harness connector and look at the place on the board where the connector plugs, make sure it all looks good and is clean. Only pull one connector at a time and remember the position of the connector, this machine is not like the old ones. It can get a little intimidating but it's really easy once you get the hang of it. If any of the contacts on the edge connectors looks pushed down too far you can take a sewing needle and VERY GENTLY bend the contact back into position. But be careful and be gentle. One false move and you might end up buying a new harness. |
Post# 443128 , Reply# 3   6/20/2010 at 13:08 (5,057 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 443181 , Reply# 4   6/20/2010 at 18:17 (5,056 days old) by surgilator_68 (Maryland)   |   | |
Post# 443215 , Reply# 5   6/20/2010 at 22:45 (5,056 days old) by mixfinder ()   |   | |
Jason you made milk come out my nose! |
Post# 443223 , Reply# 6   6/20/2010 at 23:42 (5,056 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
What happened to that washer? It really looks like it has been run though the mill. Is there a chunk of plastic missing from the front widow? Looks like dogs clawed the hell out of the plastic on the door. |
Post# 443249 , Reply# 7   6/21/2010 at 01:45 (5,056 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 443251 , Reply# 8   6/21/2010 at 01:50 (5,056 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 443252 , Reply# 9   6/21/2010 at 01:54 (5,056 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 443253 , Reply# 10   6/21/2010 at 02:00 (5,056 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 443279 , Reply# 11   6/21/2010 at 06:59 (5,056 days old) by surgilator_68 (Maryland)   |   | |
Post# 443280 , Reply# 12   6/21/2010 at 07:00 (5,056 days old) by surgilator_68 (Maryland)   |   | |
Post# 443420 , Reply# 13   6/21/2010 at 17:49 (5,055 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 443472 , Reply# 14   6/21/2010 at 21:44 (5,055 days old) by surgilator_68 (Maryland)   |   | |
Post# 443604 , Reply# 15   6/22/2010 at 13:59 (5,055 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
Post# 444024 , Reply# 17   6/24/2010 at 00:03 (5,053 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
What probably happened is those dogs thought that clothes being washed was "entertaining" for them and they jumped at the door trying to "catch" the prey (the laundry). I've seem television sets damaged the same way from dogs. |
Post# 444450 , Reply# 18   6/25/2010 at 14:55 (5,052 days old) by Irishwashguy (Salem,Oregon.............A Capital City)   |   | |
