Thread Number: 29121
65 Kenmore 800 |
Post# 443435   6/21/2010 at 19:09 (5,056 days old) by norgeway (mocksville n c )   |   | |
Here is one of my projects,wont spin but looks good,if I can fix it im going to use it for a daily driver. |
Post# 443442 , Reply# 1   6/21/2010 at 19:19 (5,056 days old) by Gyrafoam (Wytheville, VA)   |   | |
Likely needs a basket-drive. I forgot how pretty that one is! |
Post# 443444 , Reply# 2   6/21/2010 at 19:21 (5,056 days old) by norgeway (mocksville n c )   |   | |
I have it,thanks Steve! |
Post# 443447 , Reply# 3   6/21/2010 at 19:27 (5,056 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 443451 , Reply# 4   6/21/2010 at 19:46 (5,056 days old) by appnut (TX)   |   | |
Post# 443477 , Reply# 5   6/21/2010 at 22:15 (5,056 days old) by 70series ( Connecticut.)   |   | |
It does look good. Hopefully the issue preventing it from spinning can be quickly resolved. This model was probably on the showroom floor the longest of any one model during that time period. It debuted in 1965, and was still being sold in 1968. Have a good one, James |
Post# 443534 , Reply# 6   6/22/2010 at 06:00 (5,055 days old) by Gyrafoam (Wytheville, VA)   |   | |
I found it stange that it has "issues" considering when you look up under it or inside of it , it appears that it has hardly been used! The tub and Roto-Swirl are like new! I did not realize this model was continued for so many years. |
Post# 443784 , Reply# 7   6/23/2010 at 07:12 (5,054 days old) by surgilator_68 (Maryland)   |   | |
There are so many reasons why it isn't spinning. You'll have to check for each one before you go replacing anything. Loose/worn belt, broken wig wag wire, lid switch broken, timer, bad wig wag, broken or stuck wig wag plunger, stuck, bent, binding cam bar. It really shouldn't be that difficult to figure out.
