Thread Number: 29126
GE Potscrubber dishwasher |
Post# 443615 , Reply# 1   6/22/2010 at 16:20 (5,054 days old) by volsboy1 (East Tenn Smoky mountains )   |   | |
Well they have been changing there formula by removing phosphates and some of them add silica it's like a fine sand in them.The only Liquid detergent that have found that works is Palmolive Eco Gel.It's not as good Cascade complete used to be but out of all these new ones it works the best.I just don't like Gel detergents for dishwasher's every repair man that I have ever talked to say the gum up the machine.Do you use Jet Dry that might help also..
Post# 443629 , Reply# 2   6/22/2010 at 17:35 (5,054 days old) by Dustin92 (Jackson, MI)   |   | |
we have tried the palmolive eco gel and the dishes looked worse than when they went in! our jet dry dispenser is broken, so no we dont use it except when we get the kind in the basket that you hang from the rack. |
Post# 443675 , Reply# 3   6/22/2010 at 19:33 (5,054 days old) by stevet (West Melbourne, FL)   |   | |
Dustin, I emailed you earlier but see you are here again so if you can add the model number it will help all of us to see what the actual design is of the machine and help to troubleshoot it for you. Even a BOL machine should do better than what youare seeing. |
Post# 443700 , Reply# 4   6/22/2010 at 20:45 (5,054 days old) by Dustin92 (Jackson, MI)   |   | |
the model # is GSD2230Z05WW |
Post# 443885 , Reply# 6   6/23/2010 at 14:46 (5,053 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
We have used the Palmolive Eco Gel (Lavender) with STTP and got excellent results. Has anyone tried Walmarts Great Value with STTP? How does it do? |
Post# 443910 , Reply# 8   6/23/2010 at 16:05 (5,053 days old) by mrcleanjeans (milwaukee wi)   |   | |
Soaking the affected items in vinegar should remove the offending residue! |
Post# 444197 , Reply# 9   6/24/2010 at 18:13 (5,052 days old) by strongenough78 (California)   |   | |
Have you tried Electrasol Finish powder? I've been using that for a while now and get great results with it. We have very hard water here and with a little Jet Dry, everything comes out clean and clear. Also, I always run the hot water in the sink to be sure that the water that comes into the kitchen for the sink as well as the dishwasher is also hot so it doesn't start the cycle cold.
Post# 444257 , Reply# 10   6/24/2010 at 22:03 (5,052 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There is no food filter system in these machines, no power shower on top and no full wash arm under the top rack. I have found when I have used basic GEs they don't do nearly as thier better models. You have to load very lightly so water can really circulate to all areas and results can be satisfactory.
Post# 452885 , Reply# 12   7/29/2010 at 21:55 (5,017 days old) by awooff (Peoria, Illinois)   |   | |
Post# 453475 , Reply# 14   8/1/2010 at 09:37 (5,015 days old) by wmlask (Spring Grove, IL)   |   | |
Any suggestions as to which detergents still have phosphates in them? Thanks, |
Post# 453499 , Reply# 15   8/1/2010 at 10:45 (5,015 days old) by Toggleswitch (New York City, NY)   |   | |
Post# 457159 , Reply# 16   8/15/2010 at 19:29 (5,000 days old) by mark_wpduet (Lexington KY)   |   | |
