Thread Number: 29179
rust in DW tubs |
Post# 444174   6/24/2010 at 16:08 (5,052 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 444621 , Reply# 1   6/26/2010 at 07:03 (5,051 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
Post# 444678 , Reply# 2   6/26/2010 at 12:11 (5,050 days old) by roto204 (Tucson, AZ)   |   | |
It depends on whether it's surface rust or coming up from underneath. Frequently, I find that some piece of twist-tie or other steel/iron-based bit of trash flecked off and landed in the sump, and laid there for a while--the resulting rust stained the porcelain, but could be scrubbed off relatively easily with a bit of Comet.
Usually, if it's rusting out, you'll see a different texture to it, where it becomes apparent that the rust is coming through and/or dislodging the porcelain. If it looks to be a touch of surface rust, I'd try cleaning the stain with a bit of cleanser and seeing if it goes away, then keeping an eye on it to see if it comes back. |
Post# 444679 , Reply# 3   6/26/2010 at 12:12 (5,050 days old) by roto204 (Tucson, AZ)   |   | |
