Thread Number: 29261
Miele Dishwasher Question. |
Post# 445190   6/28/2010 at 08:03 (5,044 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 445192 , Reply# 1   6/28/2010 at 08:31 (5,044 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 445255 , Reply# 2   6/28/2010 at 13:21 (5,044 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 445257 , Reply# 3   6/28/2010 at 13:25 (5,044 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 445270 , Reply# 4   6/28/2010 at 14:30 (5,044 days old) by washmeup (scottsdale)   |   | |
Did you find the salt resevor? If not, it is a large cover in the base of the machine that you unscrew. If there is not any water in it when you open it you must prime it with water first. Fill it full over water and then add the salt and let the water overflow into the machine. When full of salt, replace the screw down cap firmly and run the machine without anything in it. I hope this helps!!
Post# 445278 , Reply# 5   6/28/2010 at 14:57 (5,044 days old) by bewitched (Italy)   |   | |
Hi did you check the drain pump? The filters are clean? Is there enough water inside the machine? If you tell me the exact model number then I might be able to help. Marco |
Post# 445290 , Reply# 6   6/28/2010 at 16:02 (5,044 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 445445 , Reply# 7   6/29/2010 at 06:51 (5,043 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 445491 , Reply# 8   6/29/2010 at 10:13 (5,043 days old) by nmassman44 (Brooksville Florida)   |   | |
More than likely its something clogging the drain pump. If you take the filter assembly out you will see on the left a wire holding the drain pump housing. If you push the wire off the housing it should come straight up. There is a check ball in the housing. Check to see if there is a blockage there. The water will also flush back thru the hose and into the sump. You can also move the pump impeller as well.
If they called for a repairman from Miele its going to be pricey. Just fair warning. If they called someone that says they fix Miele I would be leary about that. Miele holds onto replacement parts for dear life and you cannot find them just anywhere. |
Post# 445756 , Reply# 9   6/30/2010 at 07:36 (5,042 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Model Number is G863SCVI.
Took out the drain valve etc. Nothing seems to be dirty. Cleaned the filter, reassembled. Started the machine. Went through 2 cycles and would not advance past the second drain. Hence the Inlet/Drain light flashing. Do you know of any good service on the South Shore ? Thanks, Eddie |
