Thread Number: 29373
I miss my Maytag 806 |
Post# 446861 , Reply# 1   7/4/2010 at 08:31 (5,037 days old) by polkanut (Wausau, WI )   |   | |
Post# 446909 , Reply# 2   7/4/2010 at 12:00 (5,037 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Toss some antifreeze into the tub so it goes into the drain and it ought to be fine, just lay the drain hose down on the ground first to remove any remaining water.
Hookups are easily installed, even gas. If I move to Mt. Carroll, IL I might be able to assist with that. As for the steps, those will require measuring and looking. Dave |
Post# 446991 , Reply# 4   7/4/2010 at 17:37 (5,037 days old) by yogitunes (New Jersey)   |   | |
worst case would be to dis-assemble and then re-assemble in the basement....have done this a few times...depends how far you have to take it apart....or what about another room in the house, maybe in the kitchen, run water and drain from basement, or connect to sink....give us some specs and maybe we can help....
Post# 447059 , Reply# 8   7/4/2010 at 21:54 (5,036 days old) by qsd-dan (West)   |   | |
If the washer won't fit through the doorway, the dryer is most certainly screwed. Taking the cabinet off of the washer would probably be just enough to maneuver it around tight corners since the 'tree' and base can pivot independently. The dryer is a totally different story though.
I hope you find away to get the machines under a roof in the near future. Sitting outside and being exposed to the elements, not to mention moisture and wide temperature swings, won't do the electronics any good. |
