Thread Number: 29374
Maytag DE608 does not shut off. |
Post# 446882 , Reply# 1   7/4/2010 at 10:48 (5,043 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 447002 , Reply# 3   7/4/2010 at 18:26 (5,043 days old) by redcarpetdrew (Fairfield, CA)   |   | |
The plastic piece that strikes the bell is just that: a bell striker. When the dryer senses the load's dry, the solenoid activates and does two things; it pulls the slide over in the control switch and it rings the bell. There is a cooldown thermostat that keeps the motor running until it senses the temp in the drum has 'cooled down' and then it opens and kills power to the motor. Or you can stop the motor by opening the door. I'd check the cooldown thermostat and make sure it's open when cold (as opposed to a heating thermostat which is CLOSED when cold...).
BTW, the plastic piece with the striker probably fell down inside the dryer. They can still be found. RCD |
Post# 447003 , Reply# 4   7/4/2010 at 18:28 (5,043 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 447104 , Reply# 7   7/5/2010 at 05:45 (5,042 days old) by SYSCO ()   |   | |
It's been working with the same electrical connection for 30 years, so I would have to assume (yes, I know what happens when one assumes) that it continues to function properly. |
Post# 447217 , Reply# 9   7/5/2010 at 16:18 (5,042 days old) by goatfarmer (South Bend, home of Champions)   |   | |
