Thread Number: 29503
A DG409 won't shut off! |
Post# 448680   7/12/2010 at 13:08 (5,007 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
I'm traveling through the midwest having all sorts of fun and right now I'm at a friend's house in Decatur, IL facing a bit of a problem. They have a Maytag center dial set (A108 and DG409). I am completely unfamiliar with the 09 series of center dials. The problem is that the dryer won't shut off on a moisture-sensing cycle. It shuts off just fine on a timed cycle, but the sensor cycle just keeps on running.
I am familiar with moisture sensing dryers shutting off too soon because of a waxy buildup on the sensors, but not shutting off is new to me. The dryer is a "Big Load" style not a Halo of Heat and the end of cycle chime is a buzzer, not a bell. Anyone have any thoughts? Dave |
Post# 448701 , Reply# 1   7/12/2010 at 16:12 (5,007 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 448705 , Reply# 2   7/12/2010 at 16:22 (5,007 days old) by appliguy (Oakton Va.)   |   | |
It uses what Maytag calls Auto Dry Contorl, which is basically a thermostat in the exhaust system measures the temp of the air leaving the dryer and when it gets to the preset temp the thrmostat turns off the heat and turns on the timer. Then when the temp falls below the preset temp the thermostat turns off the timer and turns back on the heating elemet. this process keeps going until the timer goes into cool down. David the best way to know for sure if this is an Auto Dry Control dryer is to look at the dial. If i am not mistaken the Auto Dry Control Dial has an Automatic Regular and Automatic Permanent Press Cycle. On both of these cycles you set the dial towards more or less dry depending on how dry you want the clothes. Also there will bhe a timed dry cycle. Another way to know for sure is to look at the baffles in the dryer, if the don't have a metal strip on them then it is an Auto Dry dryer. If it is an Auto Dry Control Dryer it sounds like maybe the cycling thermostatr may be bad......can anyone else deny or confirm this?????PAT COFFEY
Post# 448723 , Reply# 3   7/12/2010 at 17:15 (5,007 days old) by qsd-dan (West)   |   | |
Post# 448727 , Reply# 4   7/12/2010 at 17:23 (5,007 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 448747 , Reply# 5   7/12/2010 at 19:07 (5,007 days old) by qsd-dan (West)   |   | |
Post# 448754 , Reply# 6   7/12/2010 at 19:45 (5,007 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This is temperature sensing auto dry system. It may have a bad thermostat or timer or even a broken wire from the thermostat. But most likely it has a bad vent system, make sure the vent is completely clean and assembled by the installation instructions. A long or blocked vent will cause the heater to cycle on the high limit thermostat and the operating thermostat will not cycle and the dryer will never shut off even though the clothes will eventually dry. MT was not smart enough to use a three wire hi limit thermostat so when they had a clogged vent they never shut off. The HOH DE407s did the same thing.
Post# 448757 , Reply# 7   7/12/2010 at 20:03 (5,007 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 448904 , Reply# 8   7/13/2010 at 11:35 (5,006 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
There are 2 and they are on the intake duct to the blower from the tumbler. They both have 3 wires and the wiring looks good. I can't tell which one is which, however, because the paper tag on each thermostat has fallen off and they were laying in the bottom of the cabinet. I'm looking on the Sears Parts Direct website's diagrams to identify which one is the cycling thermostat.
Dave |
Post# 448916 , Reply# 9   7/13/2010 at 12:17 (5,006 days old) by super32 (Blackstone Massachusetts)   |   | |
this dryer should have 2 bottons to the right of the center dial? regular temp and delicate temp? The 2 t'stats, 1 is regular temp and the other is delicate. Unfortunatlly, i dont remember which one is which. If you find a parts look up, it should say.
Also i should ask, does the dryer seem to dry ok? heating ok? The reason i ask is, i have seen a few cases where, a customer will say, it wont shut off. Well come to find out, the gas coils start giving out and short cycling. It never gets hot enough to trigger the operating t'stat. This type of case usually happens to people that will put clothes in before bed or before work. They get up and/or come home to dry clothes but the dryer is still running. Hope this helps. |
Post# 448999 , Reply# 10   7/13/2010 at 18:11 (5,006 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 449019 , Reply# 11   7/13/2010 at 19:46 (5,006 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Dave both thermostats on the blower housing cycling thromostats, one is the low temp the other is the high temp. They are easy to test and if its the thermostat it would work on the other temperature. I would do a little more checking before spending money on possibly unneeded parts, you can always call if in drought.
Post# 449025 , Reply# 12   7/13/2010 at 19:56 (5,006 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
