Thread Number: 29564
Uh-Oh: The Dreaded Bearing Roar Has Commenced! |
Post# 449406   7/15/2010 at 08:13 (5,032 days old) by Frigilux (The Minnesota Prairie)   |   | |
Well, kids, on what is probably my 2002 Frigidaire front-loader's eighth birthday, the "roar of the spin" has begun. I was washing a load of bath towels and could hear it spinning upstairs at the opposite end of the house.
I thought the racket might be caused by a rapidly spinning unbalanced load, but upon inspection found it to be an almost perfectly balanced spin. The sound isn't a squeal/squeak; it's kind of a very loud whirring or a dull roar, as if gunning a car engine while in neutral. I pulled the load out at the end of the cycle and spun the tub by hand. There's a bit of growling. I'm guessing it's the bearing. Can anyone who's familiar with this malady confirm my suspicion? I'm actually not terribly surprised, as A) the 3.0 cu. ft. machines were notorious for this failure, and B) the machine has been oversudsed a hundred times, and liquid chlorine bleach is used in at least 3-4 loads per week. I'm curious as to how quickly the situation will deteriorate, and how many more loads I'll get from it before it grinds to a halt---speaking of which, if the bearing fails will the tub attempt a violent escape from its confines at 900 rpm, or does that only happen with a spider failure? Time to start saving the nickels and dimes for a new set. The big question: Whirlpool, Maytag, LG, GE, or perhaps the new Frigidaires? All comments, advice, and anecdotes are welcomed! |
Post# 449414 , Reply# 1   7/15/2010 at 09:15 (5,032 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
if you use bleach 3 4 times a weeks and the washer tends to suds alot maybe i would go with a toploading washer and i know that whirlpool and maytags are very good since they have a toploading washer that has a three spray rinse and you can also select the washe speed as well
Post# 449426 , Reply# 2   7/15/2010 at 10:12 (5,032 days old) by cfz2882 (Belle Fourche,SD)   |   | |
it's the bearings-pretty easy fix if you are used to washer repair,though does- require quite a bit of dissasembly-can give details if you want... |
Post# 449482 , Reply# 3   7/15/2010 at 14:17 (5,032 days old) by qsd-dan (West)   |   | |
Post# 449502 , Reply# 4   7/15/2010 at 16:10 (5,032 days old) by LordKenmore (The Laundry Room)   |   | |
If the current bearings can be replaced, that might be worth looking into.
If you do replace, you might add Speed Queen and Miele. These options would cost more, but could cost a less in the long haul--both in lower dollar costs and in aggravation since they (shouldn't) need to be replaced as often. Unfortunately, these brands might not be viable if you are planning on buying locally, however. I have no real experience past hearsay with any front loader. But one thing I'd be looking at if I were buying new (slim chance of THAT ever happening!) is the country where the washer was made, and also who owns the company. My preference would be to buy US product. (I know that I suggest Miele, but I'm less concerned with buying German than Asian.) Thus, I'd rule LG and probably Frigidaire out. Another thought: instead of talking about a new "set" (I assume you're thinking of both washer and dryer), you might consider just the washer. If the dryer is still working, you might as well continue using it until it's run into the earth. By doing this, you could possibly afford a better washer (Speed Queen instead of Whirlpool). Plus, long term, by buying separately, one can select the appliance that is the best possible choice. While different brands won't "match," my personal bias is entirely towards practicality--getting the best possible job for my particular circumstances. |
Post# 449504 , Reply# 5   7/15/2010 at 16:23 (5,032 days old) by LordKenmore (The Laundry Room)   |   | |
"G.O. V.I.N.T.A.G.E!"
This is also an idea well worth considering. I have had little experience with modern washers, but what experience I've had has been--oh, how do I put this nicely?--disappointing. The only plus I see to modern is that the capacity is big--at least compared to the vintage machines I'm used to. I wouldn't mind having a modern machine just for that capacity--but I'd never use it unless washing stuff too big for the belt drive Kenmore. With 99% of my loads, the Kenmore is quite adequate. |
Post# 449549 , Reply# 6   7/15/2010 at 19:58 (5,032 days old) by yogitunes (New Jersey)   |   | |
Post# 449553 , Reply# 7   7/15/2010 at 20:11 (5,032 days old) by appnut (TX)   |   | |
Eugene, I say get one of the new Frigidaires that was recently announced. 4.4 cu. ft. capacity AND with the sanitary cycle and prewash options and steam, I understand you couldo do basically a profile wash. And you wouldn't have to use chlorine bleach anymore--oxygen bleach like OxiClean. Besides the TOL model has a specialty cycle for washing teddy bears. Although I'd prefer washing mine in the shower or bath tub with me ;-)
Post# 449563 , Reply# 8   7/15/2010 at 20:32 (5,032 days old) by Frigilux (The Minnesota Prairie)   |   | |
Pierre---I have a 2006 Frigidaire top-loader, but I use it only occasionally. It isn't a great washer, but I enjoy watching the indexing tub. I prefer front-loaders, and my '02 front-loader is my "daily driver".
cfz2882---while many at AW are blessed with the skill and patience to take on major repairs, I am not one of them, LOL. Although I hate to break up the identical-looking Frigidaire triplets in my laundry room, I think I'll try something new when the time comes to replace the front-loader. I'm not at all a fan of my Frigidaire dryer, with it's puny 5.8 cu. ft. drum. Dan---While it would be fun to have a vintage washer, I'd prefer to have a new front-loader as my "daily driver". I'm not mechanically inclined, so I need a washer which can be repaired by one of my local dealers. John---I don't have a Speed Queen or a Miele dealer anywhere near me. The brands listed above are the ones I can get locally. A shiny new Miele would certainly be a wonderful choice! When I replace the washer, I'll also replace the dryer, as I don't really like it. Martin---While the newest line of Frigidaire washers/dryers have many improvements--and the price is reasonable--I've already owned a Frigidaire pair and would like to try a new brand. The LG 2050 is highly recommended by Consumer Reports, as well as by a friend who owns one. It doesn't sport all the bells and whistles of a top-of-the-line LG, but it and its companion dryer can be had for about $700 each. I'll have to see how long my current Frigidaire lasts. If it has another year of service left, I can probably save up for a TOL LG pair, or perhaps a Whirlpool or Maytag pair. If it will need to be replaced in six months, I'll probably opt for the LG 2050's. |
Post# 449564 , Reply# 9   7/15/2010 at 20:35 (5,032 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
LCB does not cause seal and bearing failures in FL washers. In fact Jason and I have proved by hundreds of customers experiences that the reverse is true, LCD will extend the life of most FL washers. I don't know where these stupid rummers get started but somebody needs to come up with some proof of this stupid idea that LCD is the cause of any problems.
Post# 449577 , Reply# 10   7/15/2010 at 21:22 (5,032 days old) by Frigilux (The Minnesota Prairie)   |   | |
Bob---Had I not already owned a Frigidaire front-loader, I'd probably put the TOL new one at the head of my list. It has many features (steam, profile wash, 1300 rpm spin speed, prewash, huge capacity, etc) for $1000. Since I've already owned a Frigidaire, I'd like to try a new brand.
I've never owned a GE or an LG, and between the two of them, I'd probably go with LG. Then there's always the Whirlpool Duet or its Maytag sibling to consider. We'll see what plays out when the time comes. It all depends upon how long my current machine lasts. Except for this bearing issue, I've never had a single problem with my Frigidaire front-loader in eight years. LG's are now listed as the most reliable front-load brand by Consumer Reports (9% needing repairs), followed by Whirlpool and Frigidaire (11% needing repairs). LG-made washers make up six of the top eight machines tested by Consumer Reports. The LG 2050 comes in fifth, with a total score of 83, while a similarly priced/featured LG-made Kenmore tops the list with a score of 85. The other two machines in the top eight are Samsungs. John--Thanks for the info about using chlorine bleach in front-loaders. I'm a big fan of LCB, so I have no plans to stop using it. I think it's one of the reasons I've never had a mold/mildew issue with a front-loader. |
Post# 449578 , Reply# 11   7/15/2010 at 21:28 (5,032 days old) by LordKenmore (The Laundry Room)   |   | |
Given that the dryer is important, you might look the hardest at Whirlpool/Maytag. I knew someone shopping for a dryer a few months back, and asked about modern dryers here. The largest number of votes were for Whirlpool.
Past that, I like that Whirlpool still makes appliances in the US. I'm far from "buy American or die!" But I do think it makes a lot of sense to buy a US product whenever it's a reasonably competent product. If I were buying new, I could see buying a Miele instead of a Whirlpool. But the case for LG--for me--is just about impossible to make. But that's just me. The other thing that may be "just me" is that if I were shopping, I'd be looking at buying as cheap as possible. Rock bottom may not be the best choice--but in the disposable appliance era, buying something expensive (unless it's Miele) doesn't make sense to me. Even though the dryer is on the hit list, it might still be worth considering it a separate purchase. That way, you have fewer pennies to save before buying the washer. |
Post# 449581 , Reply# 12   7/15/2010 at 21:45 (5,032 days old) by LordKenmore (The Laundry Room)   |   | |
Post# 449586 , Reply# 13   7/15/2010 at 22:14 (5,032 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
here is a tip if you want to protect the bearings of your frigedair fl washe and rinse in your fridegedair fl but for the spin part of the cycle transfer the wet clothes in your fridgedair topload that you set on the spin cycle and then transfer the clothe back to your fl fridgedair washer for the rinse part of the cycle.
Post# 449646 , Reply# 15   7/16/2010 at 00:40 (5,031 days old) by yogitunes (New Jersey)   |   | |
The FL you have is one of the better of the Frigidaire lines, the TL is too cheaply made....I would just stay away from the newer ones, I have the gallery series with the large square door, digital, and you cannot adjust the water level, although I have figured a way to do it, same goes for their Affinity version of these washers, works with drops of water, which is no where near enough.....
If you want the same machine you have again, check for a SEARS OUTLET in you area, discontinued models may be there at a discounted price, can't hurt... Do what I do, when considering a new machine, I take a screwdriver in with me and open the machine up to see what its made out of and if I can adjust the water level if needed...you should have seen the shock on the cashiers faces in Sears when I did this, I want to know what I'm paying for this time around...you can also try a rent-a-center and try a few brands out before deciding....although most places will give you a refund if its not to your liking |
Post# 449658 , Reply# 16   7/16/2010 at 01:22 (5,031 days old) by sudsmaster (SF Bay Area, California)   |   | |
Here's an excerpt from the Bosch Axxis washer manual:
"Bleaching DO NOT use chlorine bleach in this washing machine. Decolorizing Decolorants may contain sulphur or chlorine. These substances can cause parts of the wash- ing machine to corrode. Do not decolorize items of laundry in the washing machine." The corrosive nature of chlorine is well known. Stainless steel is particularly vulnerable to its action. The chlorine strips away the protective layer of chromium oxide from the surface of the stainless steel, rendering it susceptible to corrosion (rust) just like plain steel is susceptible. Chlorine can also attack rubber items, accelerating their deterioration by the oxidation process. Chlorine bleach being a strong oxidant. I'd like to know how someone has "proved" that chlorine bleach prolongs the lifespan of washers... I've never used chlorine bleach in my Neptune. It has zero mold/odor issues, and the bearings are just fine, after 10 years of regular use (average of five loads a week). Miele washers last for decades without ever seeing a drop of chlorine bleach. CLICK HERE TO GO TO sudsmaster's LINK |
Post# 449697 , Reply# 17   7/16/2010 at 07:55 (5,031 days old) by nunyabidness ()   |   | |
Whirlpool & Maytag will soon be making a frontloader in the US. The launch is scheduled for later this year, but there are some pics at the forum post below. CLICK HERE TO GO TO nunyabidness's LINK |
Post# 449724 , Reply# 18   7/16/2010 at 09:27 (5,031 days old) by sudsmaster (SF Bay Area, California)   |   | |
You might want to look for the new Electrolux line of front loaders. Large capacity and reversible washer doors caught my eye, as well as a sanitize option (internal heater) on all models. They've been out for at least a year now.
Doesn't look to me that the new Frigidaire front loader (4.4 cu ft Affinity) is the same machine, though. And it can be hard to find a dealer for Electrolux brand front load washers/dryers. |
Post# 449820 , Reply# 19   7/16/2010 at 15:33 (5,031 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
I'll probably be flamed for this, but I was pretty impressed with the Samsung FL machines we looked at recently. They looked like they were built from decent quality parts, well at least the exterior & drum appeared to be. |
Post# 449877 , Reply# 20   7/16/2010 at 20:23 (5,031 days old) by Frigilux (The Minnesota Prairie)   |   | |
You are completely safe, here, Allen. I agree about the Samsung machines---they do seem to have a more solid build quality than, say, a Frigidaire.
While I admire vintage washers, I'm not inclined to work on them, so I get my "washer fix" from viewing all the beautiful machines many others at AW have lovingly restored. Aside: My sister and I were in our home town of Watertown, SD over the 4th, and we located the houses we lived in, our schools (go Immaculate Conception!!), and the houses of family friends, etc. We moved from Watertown to Minnesota in 1967, when I was going into third grade. My sister was in her 2nd year at college. As we located houses, I'd say "They had a '59 Maytag." "They had a '63 Frigidaire." And so on and so forth. Finally, after about 8 or 9 recitations, my sister looked at me and said "You're messing with me, right? You don't really remember what kind of washer all these people had!" Oh, ye of little faith. Of course I remember. |
Post# 449950 , Reply# 22   7/17/2010 at 07:07 (5,030 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Usually when you can hear the machine all over the house the machine is not long for the world, some times its shot in a month. I would look most seriously at a new SQ FL washer ,they are made just one state away. LCB is corrosive if miss used but its not used full strength in laundry. In talking to the other repair techs here yesterday no one could come up with a single example of any SS part of a washing machine that was ever replaced because of corrosion. Yes you don't have to use LCB to keep a washer mold free, but its one good way to help do so. Using proper water temps and detergents and LCB all help keep the gunk from growing mold on the aluminum spiders, I have never seen a clean spider break they are always covered with slime and I have never seen slime that can grow in a LCB solution. Even my new SS sink had a label on it suggesting the use of LCB to clean it and keep it pretty. Bosch and others that have washers that can heat water to nearly 200F have always suggested not using LCB in thier washers. However you will now notice that now that they no longer have these 200F cycles on the new models that they have added LCB dispensers to thier washers. Poring full strength LCB on something to see if it corrodes is like taking 50 aspirins to see if they are safe,its not the correct scientific way to test something, in fact its just plain stupid and doesn't merit a response.
Post# 449992 , Reply# 26   7/17/2010 at 12:48 (5,030 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 449993 , Reply# 27   7/17/2010 at 12:50 (5,030 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 449994 , Reply# 28   7/17/2010 at 12:51 (5,030 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 450021 , Reply# 29   7/17/2010 at 13:52 (5,030 days old) by limey ()   |   | |
To Jetcone Just wish I had been as lucky |
