Thread Number: 29948
Washer pumping slow
Post# 455163   8/7/2010 at 10:24 (5,001 days old) by suds14 (Pittsburgh)
I am using my belt drive whirpool washer, the first few loads
the washer ran fine. On the fourth load the water is not pumping out before the timer advances to spin. I am wandering if the belt needs tightened or if the pump is starting going? I also just noticed it seems to be agitating a little slower also.
Any suggestions?
Thanks
David
Post# 455171 , Reply# 1   8/7/2010 at 11:00 (5,001 days old) by cfz2882 (Belle Fourche,SD)
does sound like a loose belt
Post# 455232 , Reply# 2   8/7/2010 at 15:25 (5,001 days old) by suds14 (Pittsburgh)
Thanks cfz2882. It took me a while to get the motor nut loose but I finally did, made the belt tighter, now the washer is runnung even better than before. it is so nice to have a washer with a suds saver again. I was getting tired of putting the water back into the washer with a bucket.
Thanks again,
David
