Thread Number: 30027
I just couldn't resist... |
Post# 456107   8/11/2010 at 01:26 (5,006 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 456108 , Reply# 1   8/11/2010 at 01:27 (5,006 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 456109 , Reply# 2   8/11/2010 at 01:31 (5,006 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 456110 , Reply# 3   8/11/2010 at 01:32 (5,006 days old) by lebron (Minnesota)   |   | |
Post# 456112 , Reply# 4   8/11/2010 at 01:37 (5,006 days old) by Pulsator (Saint Joseph, MI)   |   | |
I love how this machine works!
-The lid switch was a BREEZE to trick -The wash action seems MUCH gentler than HE impeller machines I've used in the past. -It uses a very generous amount of water such that you can in fact see the water level while it's running, it remains an inch or 2 below the level of the saturated clothes. -It does NOT tangle things! I threw towels at it, t-shirts, jeans, shorts, long pants, boxers, even sheets and not a single thing came out with anything else wound around it. I was able to pick up each item individually and not have any other item come up with it. |
Post# 456113 , Reply# 5   8/11/2010 at 01:41 (5,006 days old) by Pulsator (Saint Joseph, MI)   |   | |
Only a couple troubles that may be mechanical/computer faults that need to be addressed by a repairman.
-When the "Fabric Softener" and "Extra Rinse" options are selected, it states in the user manual that softener will not be dispensed until the final rinse, however it is still indeed dispensed in the first rinse it seems... I did have to stop the machine during the wash spin for a lenghty period of time in which it powered down and then skipped onto the next step when I turned it back on. It may have been my fault for shutting it off. I shall explore this problem further. -On both the Normal and Eco Normal cycles, no matter what temp is selected, it always washes in cool water. The other cycles work just fine temp wise... Not sure why this is. I have my cold water tempered to 85F and it would only fill from the cold valve. Then I tried shutting off the hot water to the tempering valve and it did indeed compensate by adding hot water to reach the same temperature that my tempering valve achieved. So it's not a problem with the valves... Not sure what's goin on there... |
Post# 456114 , Reply# 6   8/11/2010 at 01:43 (5,006 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 456134 , Reply# 7   8/11/2010 at 07:02 (5,006 days old) by appnut (TX)   |   | |
Post# 456135 , Reply# 8   8/11/2010 at 07:13 (5,006 days old) by surgilator_68 (Maryland)   |   | |
Post# 456163 , Reply# 9   8/11/2010 at 10:18 (5,006 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 456184 , Reply# 10   8/11/2010 at 12:26 (5,006 days old) by mrb627 (Buford, GA)   |   | |
Post# 456231 , Reply# 11   8/11/2010 at 14:45 (5,006 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 456247 , Reply# 12   8/11/2010 at 15:32 (5,006 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 456373 , Reply# 14   8/11/2010 at 23:23 (5,005 days old) by spinmon (st. charles mo )   |   | |
I would love to hear this type machine will work well & long. Keep us informed. My '96 shredmore ain't gettin' any younger or gentler!(and our water bills ARE creeping up). |
Post# 456566 , Reply# 15   8/12/2010 at 19:17 (5,004 days old) by Pulsator (Saint Joseph, MI)   |   | |
This IS one of the newly designed machines that uses a belt!
The price of this particular machine is $629 I believe... However, I got it for a discount and this is not the lowest model. The lid lock is very different from the F&P based machines. There is a magnet contained in the plastic of the latch, all I needed to do was removed the latch assemble from the lid (2 screws) and place it in the port and the machine is convinced it's closed and locked. So far, everything I've thrown at this machine has come out very well! Aside from the temp issue on the 2 Normal cycles and the fabric softener dispenser issue, this machine is very very nice. It's very quiet, does a good job, doesn't take forever, and doesn't tangle anything! It's gotten out several stains that I've thrown at it and if one needs a hot wash, while it's not a full 140F-160F, the Heavy Duty cycle offers a hot temp hot enough to steam up a camera and a pair of glasses! A few more things I've noticed are that this machine seems to rinse surprisingly well. So much so that things are coming out of the dryer a lot softer than I'm used to. Also, even with only an 800 RPM spin, things are coming out of the spin cycle with dry spots on them like they would if they were coming from a Unimatic! Everything dries in a very short time. |
Post# 456594 , Reply# 17   8/12/2010 at 21:51 (5,004 days old) by washernoob ()   |   | |
That is a really sharp looking machine! Nice find. Love the control panel, and the very contemporary look of the interior. |
Post# 457529 , Reply# 18   8/17/2010 at 14:40 (5,000 days old) by mrb627 (Buford, GA)   |   | |
I found the service literature for this beast. You'll need to drop the http:// from the front of the url.
Malcolm CLICK HERE TO GO TO mrb627's LINK |
Post# 457563 , Reply# 19   8/17/2010 at 17:02 (5,000 days old) by LordKenmore (The Laundry Room)   |   | |
"I found the service literature for this beast. You'll need to drop the http:// from the front of the url."
After removing the "http://", I also needed to add a colon between the "https" and the first "/" (This forms: https://). Thanks for the link, Malcom! I've been curious about this washer, and the service info will tell more than the sales literature. |
Post# 457606 , Reply# 20   8/17/2010 at 21:52 (4,999 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 457666 , Reply# 21   8/18/2010 at 01:40 (4,999 days old) by Pulsator (Saint Joseph, MI)   |   | |
Post# 457674 , Reply# 22   8/18/2010 at 02:19 (4,999 days old) by paulinroyton (B)   |   | |
Wow, what a cute machine. its sounds so quiet on the wash and spin cycles. Paul |
Post# 457682 , Reply# 23   8/18/2010 at 05:08 (4,999 days old) by LordKenmore (The Laundry Room)   |   | |
This is the link. It should work with a simple copy and paste your web browser's address bar:
secured.whirlpool.com/Service/Sr... |
Post# 457695 , Reply# 24   8/18/2010 at 06:29 (4,999 days old) by mrb627 (Buford, GA)   |   | |
Post# 457711 , Reply# 25   8/18/2010 at 08:23 (4,999 days old) by gefilterflo (Newark, Ohio)   |   | |
Post# 457719 , Reply# 26   8/18/2010 at 09:25 (4,999 days old) by mrb627 (Buford, GA)   |   | |
Here is the Service Tech Sheet that is normally found in the console.
Post# 457813 , Reply# 27   8/18/2010 at 16:48 (4,999 days old) by lebron (Minnesota)   |   | |
Post# 457839 , Reply# 28   8/18/2010 at 19:13 (4,998 days old) by vintagesearch ()   |   | |
nice seems to use sufficient water and we can see great rollover! yes i want one NOW |
Post# 457840 , Reply# 29   8/18/2010 at 19:15 (4,998 days old) by appnut (TX)   |   | |
Cute machine. Nice to see a bit more water in the tub for a HE TLer. How well does it turn over that load of towels? I love the EOC chime. It's singing--You're clothes are clean!! Your clothes are clean!! All ya need is a slant-front westinghouse dryer that plays how dry I am at the end and you'll be set!!
Post# 457870 , Reply# 30   8/18/2010 at 21:35 (4,998 days old) by mark_wpduet (Lexington KY)   |   | |
I love the way the washer looks........What bugs me the most is the wash/rinse action, in that how LONG it takes for the towels to submerge and roll over. I know that this does "eventually happen", but so much time is wasted waiting for it to happen, that I wonder if they are getting as clean and rinse as they could. I mean, when the towels at the top take three minutes to finally roll over.....I guess it's just me. Lots of people like these machines and say they get clothes clean so maybe there's more going on than what I'm seeing.
Post# 457958 , Reply# 35   8/19/2010 at 12:10 (4,998 days old) by logixx (Germany)   |   | |
Post# 457999 , Reply# 36   8/19/2010 at 17:35 (4,998 days old) by golittlesport (California)   |   | |
Post# 458002 , Reply# 37   8/19/2010 at 17:45 (4,998 days old) by mrb627 (Buford, GA)   |   | |
Post# 458034 , Reply# 38   8/19/2010 at 21:54 (4,997 days old) by Pulsator (Saint Joseph, MI)   |   | |
I like the gray wash plate in the Maytag!
For those who don't like how little water it uses, I made a vid showing how machine performs using the water cheat I found! It only takes about 3-4 minutes, here's how I do it: Put the load in sans chemical, start it, use my hand to divert the flowing water to drench the load while turning the tub to drench the WHOLE load, set the machine to spin on low speed for a few seconds, stop it, add chemicals, set controls and start it. It senses the weight of the load and determines the correct water level via the weight sensing. Making the load slightly heavier makes it use more water. |
Post# 458041 , Reply# 39   8/19/2010 at 22:56 (4,997 days old) by spinmon (st. charles mo )   |   | |
But I'm not. Still sounds like a dumb teenager continually hitting the gas & letting off in his mom's slant 6 Valiant. Hope it does good for you. |
Post# 458043 , Reply# 40   8/19/2010 at 23:05 (4,997 days old) by spinmon (st. charles mo )   |   | |
They should've used a little more PLASTIC. I AM sorry to be harsh,but my disappointment cup overfloweth like our '63 Frigidaire Imperial rinse cycle used to. Nevermore. |
Post# 458056 , Reply# 41   8/20/2010 at 00:24 (4,997 days old) by Spiceman1957 ()   |   | |
A very modern looking machine with lots of bells and whistles John |
Post# 458081 , Reply# 42   8/20/2010 at 04:32 (4,997 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 458084 , Reply# 43   8/20/2010 at 06:05 (4,997 days old) by logixx (Germany)   |   | |
Post# 458106 , Reply# 44   8/20/2010 at 08:02 (4,997 days old) by whitetub (Montreal, Canada)   |   | |
How big is the load on your last video? It seems like such a small load compared to the size of the tub. Do these machines ever get filled up all the way to the top (or at least 3/4 ) ??? |
Post# 458112 , Reply# 45   8/20/2010 at 08:41 (4,997 days old) by mark_wpduet (Lexington KY)   |   | |
It probably was filled to the top, but like it a front loader, once the load is wet, it tamps down a lot. Perhaps you're not supposed to fill above a certain line on the tub either. I agree though, every vid I've seen with these machines the load doesn't appear to be very large.....It's hard to tell because the tamp down so much when wet.
Post# 458119 , Reply# 46   8/20/2010 at 09:10 (4,997 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Congratulations on the new machine!
I guess most people who have toploaders with a wash plate have the tendency of not filling them up to the top as they used to do with traditional agitators. On Youtube there are only a few videos that appear to be filled to the top. So the question is Jamie, how full was your machine when you filled it? It's the same for frontloaders actually. There are hardly any movies of American sized frontloaders that are filled to capacity. Europeans are used to fill frontloaders properly, with only a little space on the top left. |
Post# 458131 , Reply# 47   8/20/2010 at 11:14 (4,997 days old) by mrb627 (Buford, GA)   |   | |
Post# 458151 , Reply# 48   8/20/2010 at 13:38 (4,997 days old) by Pulsator (Saint Joseph, MI)   |   | |
I have tried filling it to the top before, actually, I've done 2 Bobloads in it! It usually squishes everything down to about 2/3 full when there is a HUGE load in it. I have yet to try a Bobload in it with my new water trick. I tried out the Clean Washer cycle to see what it would do and it fills all the way to the rim of he tub with HOT water! So it's not like it won't fill up a ton. I just wonder what it will do with a Bobload and my new water cheat... I'll be sure to take a video of that!
Also, even without the water cheat, both Bobloads came out flawlessly. No more stains (they were nasty loads), nothing tangled, and everything soft and fresh smelling! I did have to split the loads between 2 dryers each though... |
Post# 458155 , Reply# 49   8/20/2010 at 14:30 (4,997 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 458190 , Reply# 50   8/20/2010 at 20:51 (4,996 days old) by mayguy (Minnesota)   |   | |
Jamie, when you do your bobload, be sure to a video of it full and dry load and the machine starting up and doing it's fill. |
Post# 458241 , Reply# 51   8/21/2010 at 07:14 (4,996 days old) by Frigilux (The Minnesota Prairie)   |   | |
I read in the service manual (kindly linked above by Malcolm) and it reassured the user that water should not cover the load as with a traditional top-loader, because the extra water will lift the clothes off the impeller, thus reducing cleaning power and increasing tangling.
This is a case where less water produces better results. Even if it is a bit painful to watch, LOL! |
Post# 458242 , Reply# 52   8/21/2010 at 07:25 (4,996 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 458245 , Reply# 53   8/21/2010 at 08:10 (4,996 days old) by mrb627 (Buford, GA)   |   | |
On the subject of excessive fabric wear and tear imposed by top loading HE washers, I think by and large most users select the incorrect cycle and/or a longer washing time than required by the load being washed. I know I am guilty of this too. When I had my GE Harmony pair, I would frequently ramp up the soil level to the maximum because I felt that more was better. I began to notice towels fraying around the edges and shirts pilling out of control.
Painfully, over the years, I am getting used to the idea that less is more. I remember reading a report somewhere a while back that indicated that the majority of the soil in a load of laundry would be shifted in the first four minutes of agitation. Superior results would come from a short prewash followed by a short main wash rather than a long wash cycle alone. When I had my LG set, I used to always include a prewash with every cycle or my results would end up poor. That is, I would select a light soil level then add a prewash. Listen to me ramble on.... Malcolm |
