Thread Number: 30036
New Miele DW filter...sigh |
Post# 456270   8/11/2010 at 17:33 (4,998 days old) by drhardee ( Columbia, SC)   |   | |
The filter assembly in my 2005 Miele Premiere Plus has worn out. The small yellow flap in the bottom of the assembly which one opens to clean out the filter is hinged on one side by the thinnest of plastic hinges. It's finally worn out, and the next time I open the flap will, I know, be the last. I called Miele to order a new filter assembly, and was not too shocked to discover they are $85.00 and $15.00 shipping from NJ to SC. I was hoping to get more than 5 years' service out of an integral part of the DW. I could have attempted to fix it with super glue, but decided against it. It's been a fine DW, and bloody well should be for the $2,450.00 MSRP! Thank goodness I got a floor model for 1/2 that figure.
Heads up to you Miele DW owners out there...watch the hinge on your yellow filter flap! |
Post# 456283 , Reply# 2   8/11/2010 at 18:04 (4,998 days old) by drhardee ( Columbia, SC)   |   | |
Oops...my bad. It is, of course, beige. The little latch opposite the offending hinge is yellow. See pic attached.
The filter isn't clean, I know, but I don't want to be vigorous or even gently clean the filter for fear that the scrap of plastic holding it on will fail. I should have the replacement in a week or so. |
Post# 456307 , Reply# 3   8/11/2010 at 19:02 (4,998 days old) by robliverpool (england Liverpool)   |   | |
Post# 456827 , Reply# 4   8/13/2010 at 20:40 (4,996 days old) by jerrod6 (Southeastern Pennsylvania)   |   | |
I had this happen on my previous Miele after 10 years. The bottom of the filter(the yellow part) will still latch even if that flap is disconnected. I just put the two parts together and pressed. All was fine and once seated in the sump there were no problems. |
Post# 456942 , Reply# 5   8/14/2010 at 15:09 (4,995 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
That's what I was thinking too. Couldn't you just take the top, put it in place and apply a little bit of pressure to snap it shut? |
