Thread Number: 30112
Kitchen Aid Energy Saver V Superba by Hobart KDS 20C |
Post# 457077 , Reply# 1   8/15/2010 at 12:37 (5,001 days old) by appnut (TX)   |   | |
Lorenzo, did you put the bottom rack back in the correct direction? The two front corners of the bottom rack have some "deflectors" built into it that keep the water from coming out the front of the door. By correct direction, I mean the large plates are placed front to back on the left hand side of the rack and the smaller stuff is placed on the right hand side of the rack going rich to left.
Post# 457078 , Reply# 2   8/15/2010 at 12:38 (5,001 days old) by rp2813 (Sannazay)   |   | |
I suspect that something in the configuration with the new counters has changed the way the door seals on your dishwasher. I had this same thing happen with my 25-year old dishwasher recently when I adjusted one of the leveling feet a few weeks after installation. I did so without removing the screws where the top of the machine is secured to the underside of the countertop. As soon as I removed those screws, everything popped into place and I had no more leaks from the door. I re-fastened the upper screws into new holes and everything has been fine since.
This post was last edited 08/15/2010 at 13:32 |
