Thread Number: 30626
SQ Top Load Washer Gunk Build-Up |
Post# 463214 , Reply# 1   9/13/2010 at 14:20 (4,944 days old) by nmassman44 (Brooksville Florida)   |   | |
I never use my dispenser since all the gunk that builds up in it and down the barrel. One tid bit is that when it goes into the rinse not enough water moves thru the barrel. You will find carry over of softener into the next wash cycle..its a vicious cycle and thats how all the gunk gets built up..it will react with your detergent and thats not a good thing. Our tenant uses the dispenser and after he is thru with it I have to wash out the dispenser and flush out the barrel of the agitator. I am amazed at how much is in it. I flush it out with hot water and then spin out the water. Then I put the washer into the first spin at the spray and let the washer spin spray the tub to get rid of residue. The tenant uses Gain softener and that stinky gawd awful Lavendar Downy..both scents are way over the top for me and he doesnt use the cap to measure he pours it right into the dispenser without diluting it. So you can smell him a mile away. PU. I flush it out since I dont want any carry over onto our clothes...and he wonders why our clothes come out so clean and his doesnt...
Post# 463216 , Reply# 2   9/13/2010 at 14:39 (4,944 days old) by DanManTN (Tennessee)   |   | |
I noticed this too and am thankful that the design allows you to 'break down' the assembly to be able to clean it! Most say not to use fab softener in the dryer, which only leaves the washer. Danged if you do...
I clean it about once every 3 months--secret weapon for the barrel? A big Fuller JAR brush, works like a charm! CLICK HERE TO GO TO DanManTN's LINK |
Post# 463230 , Reply# 3   9/13/2010 at 16:40 (4,944 days old) by nmassman44 (Brooksville Florida)   |   | |
Well my secret weapon is a 2nd rinse. I double rinse every load since the washer doesnt exactly rinse residue away. Certainly not like a Maytag. They need to add more holes to the washbasket. I always add the softener manually. That way it goes into the rinse water correctly and does a better job..I think.
Post# 465683 , Reply# 5   9/26/2010 at 09:29 (4,931 days old) by LaundraMatt (Youngstown, Ohio)   |   | |
How do you take the dispenser apart? I'm afraid I'll break it. I put it in the dishwasher once, but that didn't clean it. Please help. |
Post# 465728 , Reply# 6   9/26/2010 at 14:53 (4,931 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
and the best way to avoid gunk from building up in the dispenser is to dilute the fabric sofner with water sorry if i am off subject here but in my 1993 inglis washer when i use the fabirc softner dispenser i always dilute the liquid fabiric softner and at least once a month i would start the machine on a full cycle with no clothe put hot water in the fabric sofner dispenser and let the washer run a full cycle with no clothe.
Post# 466551 , Reply# 8   9/30/2010 at 14:00 (4,927 days old) by LaundraMatt (Youngstown, Ohio)   |   | |
Its three pieces that can be taken apart? I've already taken the dispenser off the agitator and run it through the dishwasher. But you can actually take the 3 pieces apart to clean it? |
Post# 466598 , Reply# 10   9/30/2010 at 19:04 (4,927 days old) by nmassman44 (Brooksville Florida)   |   | |
for the dispenser it will come off very easily. Take your have and put it near the base of the dispenser and pull at an angle. It should come right off. Then take both hands and squeeze midway between the dispenser and it should come apart. There is the base, cup and cover. Clean in hot water and to reassemble just put the cup into the cover and snap the base with the semi circle inward and the press down onto the agitator.
When I had my Amana washer it came with a cap that if you didnt use the dispenser one could take it off and use the cap. Loved that they did that. |
Post# 466718 , Reply# 11   10/1/2010 at 15:43 (4,926 days old) by DanManTN (Tennessee)   |   | |
Post# 466758 , Reply# 12   10/1/2010 at 18:41 (4,926 days old) by JeffG ()   |   | |
We asked about that last year, Alliance claimed the caps on their commercial models don't fit their residential washers. If this is wrong info I hope someone corrects it. |
Post# 466776 , Reply# 13   10/1/2010 at 19:28 (4,926 days old) by yogitunes (New Jersey)   |   | |
I have 2 Commercial machines....took the cap off and put on the dispenser.....these are interchangeable....don't let them kid you.......
they also say you can't adjust the water level, YEAH, right! my factory set water levels just touch the tub's plastic ring for an ex-large load......but my models are from 2005..... but the hot water seems dubbed down...it doesn't flow as fast as the cold water does....and its a sealed water valve, I can't open it and inspect or make changes......may just have to take one off a maytag or whirlpool for even pressure flow.... |
Post# 467100 , Reply# 14   10/3/2010 at 15:40 (4,924 days old) by yogitunes (New Jersey)   |   | |
I might be able to get you a few caps......odd theres no part numbers in the ones I have, but no matter, their NLA anyway, even though their still put on the commercial machines....
question: I have seen in a few models for parts online...and it looks like the agitators are like the powerfin, the bottom of the fins are not connected to the base, mine are one solid piece....is this the new way SQ is making them? also, I don't understand how the inside of the agitator gets so gunked up, it has holes top and bottom to flush water thru like a powerfin, it should be self cleaning, take the cap/dispenser off and you can see water flowing thru and down as it agitates.....but yet it does.... |
Post# 467138 , Reply# 16   10/3/2010 at 19:20 (4,924 days old) by nmassman44 (Brooksville Florida)   |   | |
The thing thats missing with the agitator is openings at the very bottom/ If you look closely the bottom of the barrel has a cup shape to it so it holds the softener. To me they should have added more openings like a Maytag agitator so it would flush out completely. Also too look to see if there is any flash in the openings. Mine had 3 out of the 4 openings blocked when we got the washer and that was the bottom holes. They need to change the interior shape from the bowl shape to one that sends the softener to the edges and out the holes.
Post# 467148 , Reply# 17   10/3/2010 at 20:22 (4,924 days old) by yogitunes (New Jersey)   |   | |
what would happen if we were to drill, say, 4 large holes in the bottom of this well, the water would then flow thru and over the top of the hub.....my main concern would be gunk build up under the agitator from the softner, or would this work like Maytags powerfin, and force more water currents under the agitator and around the tub....
