Thread Number: 30691
Parting out a 1-18.... what should I keep? |
Post# 463974   9/18/2010 at 02:25 (4,963 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Hello all! I picked up a '74 - '75? Frigidaire 1-18 (below) I'm going to be dismantling for parts this weekend and I'd like to know: what parts should I keep for myself? I have a 1973 1-18 that scavenging the parts for. The washer does seem to work OK, but when it spins, it makes more noise this it should and it takes a much longer then normal time to get up to speed. Also and the end of the spin when the motor turns off, it takes FOR-EVER to coast down, like the Westinghouse top load washers of the time. I'm mainly after the tub ring seal, but I suppose it would be wise to grab the bellows, agitator, motor, water pump and.......what else would you suggest??? Yes I know I should save it, but I just simply DON'T have the room and need to make some space. I sorry but I can't save them all. Kevin |
Post# 463977 , Reply# 1   9/18/2010 at 05:08 (4,962 days old) by rollermatic (cincinnati)   |   | |
let me think here.
i would keep the motor, both bellows, pump, timer, agitator, transmission as a whole, main tub seal if it's still good. although new one's are still available. that plastic sump that bolts to the outer tub and drains into the pump i would hang onto. mine cracked but i was able to repair it. still these probably aren't around anymore. that flange that bolts to the bottom of the outer tub and holds the main tub seal i would definately keep. personally i think i would hang onto everything but the cabinet and outer tub. but that's just me!!! |
Post# 463985 , Reply# 2   9/18/2010 at 06:43 (4,962 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 463989 , Reply# 3   9/18/2010 at 08:20 (4,962 days old) by Frigilux (The Minnesota Prairie)   |   | |
Post# 464044 , Reply# 4   9/18/2010 at 13:55 (4,962 days old) by appnut (TX)   |   | |
Post# 464074 , Reply# 5   9/18/2010 at 16:54 (4,962 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 464351 , Reply# 6   9/19/2010 at 21:57 (4,961 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 464356 , Reply# 7   9/19/2010 at 22:15 (4,961 days old) by scrubflex (bronx, new york)   |   | |
Keep the inner tub also...someone may need a rust-free one. |
Post# 464359 , Reply# 8   9/19/2010 at 22:27 (4,961 days old) by qsd-dan (West)   |   | |
I can't see parting out this machine (or any vintage machine) over a spin bearing and some brake work. There's gotta be some member on the west coast that would love to have this machine in its entirety, warts and all. Pulsating Frigidaire washers are a rare commodity for the west coast as they're almost impossible to find out here.
Just my opinion though. |
