Thread Number: 30819
Testing the 1989 MW franklin...
Post# 465509   9/25/2010 at 18:46 (4,958 days old) by cfz2882 (Belle Fourche,SD)
just got a franklin built MW washer from 1989;it's the '70s/80s
style with the smaller tub and the pump under the motor.
Got for $50,it actually works perfect with no problems at all
-ran it with a fairly small load and seen that the tub indexes
about 90* in one direction while agitating,when tub is held
from indexing the rollover improves noticably...
On the final spin,it spins out the water,stops shoots in about
a gallon of water,then resumes the spin.
The drain pump is quite noisy when it sucks air and there is
some transmission gear noise when agitating.
