Thread Number: 30952
Whirlpool Thin Twin |
Post# 467172 , Reply# 1   10/3/2010 at 21:48 (4,947 days old) by 48bencix (Sacramento CA)   |   | |
The filter inlet is shown here. It was loaded. Washer Mfg ID: 3394723, Serial CJ1129381 |
Post# 467173 , Reply# 2   10/3/2010 at 21:51 (4,947 days old) by 48bencix (Sacramento CA)   |   | |
This is the control panel. So I have a question, this is a Direct Drive machine, can I lay it on it's side? Now I want to take this to our cabin, not the full size Maytag set. |
Post# 467175 , Reply# 3   10/3/2010 at 21:57 (4,947 days old) by 48bencix (Sacramento CA)   |   | |
I had to run out and take another picture, because I know you would want to see the agitatior. No dual action here. Kind of a small tub, but where I will us it that's fine. Martin |
Post# 467177 , Reply# 4   10/3/2010 at 22:04 (4,947 days old) by appnut (TX)   |   | |
Post# 467201 , Reply# 5   10/4/2010 at 00:55 (4,946 days old) by macboy91si (Frankfort, KY)   |   | |
This is essentially the later direct drive little portable washer with the portable dryer partially turned upside-down and bolted together. Small capacity and I think the dryer is still a 110v unit. It uses 220v but one leg is for the washer and the other for the dryer with a shared neutral. Basically it lets you operate the washer and dryer at the same time. It's great for small loads for 1-2 people, better than a Frigidaire unit larger capacity or not. I made the same adapter for my LK set, I can run both from a single 220v outlet in the exact same manner this machine does. I guess this machine to be 1992-ish?
-Tim |
Post# 467222 , Reply# 6   10/4/2010 at 07:57 (4,946 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This is a good compact machine they still make the same washer. This dryer does have a 3600 watt 240 volt heater and the machine is not designed to run on 120 volts. They do make a 120 volt version it has a switch on the control panel that makes you chose between using the washer or dryer only. The Question of laying washers on thier side keeps coming up I don't know if this will ever get put to rest. You can lay any top loading on its side, front loading washers are another matter they should have the shipping braces in them before laying them on thier side. This machine was made the 11th week of 1999.
Post# 467312 , Reply# 8   10/4/2010 at 19:04 (4,946 days old) by macboy91si (Frankfort, KY)   |   | |
