Thread Number: 3096
50's dishwashers and GFI outlets |
Post# 80289 , Reply# 1   8/25/2005 at 19:25 (6,811 days old) by christfr (st louis mo)   |   | |
the westy i have im sure draws a huge amount of elec to run..it could be that the gfi just trips when the flow of current is to high.. i found out this week that even if the water level is to high in the machine it will cause the motor to draw to much and trip the thermostat..so it makes sense that the gfi could be tripping from to much draw.. like greg says they are fussy machines arnt they ha ha..will the machine run fine with out the gfi outlet? |
