Thread Number: 310
KitchenAid Woes |
Post# 47259   10/17/2004 at 21:35 (7,101 days old) by DADoES (TX, U.S. of A.)   |   | |
I swapped the F&P GWL08 and DE04 for the grandmother's KitchenAid 760 pair this afternoon. As you all know, the KA pair was originally mine. I planned to hand the KA washer off to a co-worker. However, something coincidentally went wrong with the KA upon being moved. Either the spin clutch is suddenly not slipping and putting a tremendous drag on the motor, or something is bad with the motor, possibly the start winding. The machine was hand-carried across the yard to the garage 'round back, not dropped or mishandled in any way. It has been rather unstable during spin the entire time the grandmother has had it, jiggling/shaking bad enough to be alarming, but not enough to "walk." Her utility is carpeted. It was sitting rather more solidly on the concrete garage, so I hooked up the electric to check the spin. Immediately I noticed something wrong. I switched it to agitate. On, off. On, off. On, off. On, let it run for a couple mins then into drain. It seemed just a mite hesistant getting started, but otherwise ran OK. Back to spin, and it's obvious that the clutch is not slipping and the motor is under a strain. I let it run to get up to speed, and before it got there, the motor cut out for about a half-second and came back. Then it did that again. And again. I switched it to the first spin increment on Perm Press (lowest motor speed), and same thing. Finally, it did get up to speed and seemed to be running OK, except it sounded like high motor instead of low motor. Shut it off, back on, and again it's laboring. I went to disconnect the plug, and the entire power cord was noticeably warm. Not hot, but obviously a touch warm. Granny used the machine a day or two ago, nothing apparently wrong, but it's possible she wouldn't have noticed. Diagnosis? Spin clutch trouble? Or motor? Start winding? Or something specifically related to the reverse direction, since it seems OK for agitate, and for drain if it doesn't have to spin the basket. |
Post# 47262 , Reply# 1   10/17/2004 at 21:59 (7,101 days old) by coldspot66 (Plymouth, Mass)   |   | |
Were you runnimg this from a long extension cord? |
Post# 47264 , Reply# 2   10/17/2004 at 22:07 (7,101 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 47267 , Reply# 4   10/17/2004 at 22:14 (7,101 days old) by fixerman ()   |   | |
Coldspot's point is a good one also. Try plugging it directly into an outlet. |
Post# 47272 , Reply# 5   10/17/2004 at 22:46 (7,101 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 47273 , Reply# 6   10/17/2004 at 22:51 (7,101 days old) by DADoES (TX, U.S. of A.)   |   | |
Oh, and I found the agitator dogs worn out on my parents' KA this weekend . . and the softener dispenser has a mysterious hairline crack across the bottom and a little ways up the side, but it doesn't appear to affect the functionality. Of course, the cap seal is also broken. And one little ear broke off the base where the dog assembly snaps on, but I figure the nut will hold it secure, yes? I ordered an agitator repair kit, but a base it too expensive. |
Post# 47285 , Reply# 8   10/18/2004 at 00:55 (7,101 days old) by DADoES (TX, U.S. of A.)   |   | |
Won't get to check it without the extension cord being involved until the next time I get across town to the grandmother's house and have time to go out to the garage and play with it after getting into order whatever it will be that she needs gotten in order . . . which should be in the next couple days. Whew. |
Post# 47442 , Reply# 11   10/19/2004 at 23:36 (7,099 days old) by DADoES (TX, U.S. of A.)   |   | |
The extension cord was the main source of trouble. It runs OK direct to the wall outlet. Except if I start it running in spin for a sec, then stop and restart it with the clutch engaged, it has trouble getting running again. The motor could be binding a little, except it ran with no trouble in the utility room. I think the electrical circuit to the garage is weak or of just marginal capacity. The garage is actually on the lot next door that belongs to my parents, with a line running underground from the house. It handles the garage door opener OK, but I imagine that's a smaller motor. The distance of the line from the house plus the 50' extension cord definitely can't handle the washer. Anyway, that's good news for Brenda so she can get the KA washer. Now I gotta figure out what to do with the dryer. By the way, it's amazing how much quieter the F&P runs in granny's carpeted utility room, compared to the echo-chamber laundry area at my house, LOL! |
Post# 47518 , Reply# 12   10/20/2004 at 22:08 (7,098 days old) by DADoES (TX, U.S. of A.)   |   | |
What's a suitable alternative that's readily available for the 'dual-action agitator grease' called for on KA/WP/KM? RepairClinic wants $11.15 for a little tin of it!
CLICK HERE TO GO TO DADoES's LINK |
Post# 47523 , Reply# 13   10/20/2004 at 23:21 (7,098 days old) by coldspot66 (Plymouth, Mass)   |   | |
I think you can use Sil-Glyde silicone grease. It comes in a blue & red tube. Prolly avail at a hardware store. |
Post# 47525 , Reply# 15   10/20/2004 at 23:27 (7,098 days old) by fixerman ()   |   | |
Guess me and Coldspot were posting at the same time. |
