Thread Number: 31077
kdi-17 3 button control |
Post# 469129 , Reply# 2   10/13/2010 at 22:18 (4,937 days old) by 1972LKdishwash ()   |   | |
If you cannot find his number online, I have them and his fax...let me know... |
Post# 469257 , Reply# 3   10/14/2010 at 04:47 (4,937 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 469258 , Reply# 4   10/14/2010 at 04:55 (4,937 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 469267 , Reply# 5   10/14/2010 at 07:11 (4,936 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
KDC and KDI 17 dishwashers had a lot of problems with burned terminals on thier timers and pushbutton selector switches. If yours is just sticking take it out of the machine and lubricate it with a silicone lubricant thats safe for electrical items. At this point check for loose or burned terminals which will require a new or good used switch. If no switch can be found it can be electrically bypassed so the machine will run the normal cycle only. All KA four way hydro sweep arms are made with a Bakelite hub and they do ware out. Other than the new POS plastic wash arms in Fiigidare DWs and all the D & M arms that used to split at the seems we replace more KA wash arms than any other design.
