Thread Number: 31181
Maytag E2L oil leak? |
Post# 470797   10/21/2010 at 21:39 (4,907 days old) by stan (Napa CA)   |   | |
Post# 470839 , Reply# 1   10/22/2010 at 08:54 (4,906 days old) by BrianL (Saddle Brook, New Jersey)   |   | |
Eventually it will run out of oil and then damage the transmission. It depends how much or little is leaking. It will probably run for a long time. It could be a sign that water is leaking into the transmission and pushing oil out. That can have very bad results. I'm sure someone with better knowledge of these machines will chime in.
Post# 470857 , Reply# 2   10/22/2010 at 11:17 (4,906 days old) by polkanut (Wausau, WI )   |   | |
Post# 471031 , Reply# 3   10/23/2010 at 20:51 (4,905 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It depends where its leaking from. If its leaking from around the input shaft seal where the drive pulley is attached its probably not as bad. If its coming out the vent hole on top of the casing that goes to the wringer its more likely that water is leaking into the transmission around the agitator shaft seal. If you look at a sample of the oil that has leaked out you can tell if it has water in it, it will have a muddy cloudy look to it. It is true that most washers can leak oil for many many years in most cases before any harm will come to the operation of he washer. Washer transmissions are not like an automotive engines they can run on almost no oil for years.
Post# 471456 , Reply# 4   10/25/2010 at 23:13 (4,903 days old) by stan (Napa CA)   |   | |
Thanks to all, for the replies. As it turned out, I think it was, or is, two different oil leaks, one small ( little drops ) once in a while, dark brown in color, thin consistency, so little not sure where its coming from, and a one time only, (so far) from the vent hole (top casing) that was a very thick grayish brown color. After wipeing it off, and running the machine for a few more loads, it seems to have stoped? If anyone has any ideas, I`d love to hear them. Thanks Stan. P.S my E2L is a 1954 model, red bar
