Thread Number: 31207
1965 Bendix LT Washer Dryer Belt Help |
Post# 471116   10/24/2010 at 05:37 (4,930 days old) by ricky5050 (Durham Britain)   |   | |
Hi there,
I wonder if anyone can help? My daily driver is a 1965 Bendix LT washer dryer that has been performing beautifully for the last 9 years without a glitch , yesterday it made a strange noise upon spinning , i removed the back and one of the belts has began to fray, i am hoping that this is all that it is and not a gearbox fault , any way ill not know till i get a new belt. I had put this one on myself using a fan belt from an auto shop , but now i know so many experts i thought id ask you guys if replacements can be got, as the auto belt is a bit too wide for the pulley. This is a UK machine based on its American cousin so i dont mind buying for USA with postage etc. Has anyone worked on these in this country as i noticed in the workshop manual later models had an interupter switch on the gearbox to cut down the intermittent spin between rinses from 650 to 250 rpm ( which as a user it would be a good idea as it jumps from tumble 54 rpm to spin 650 in one go and when full of wet heavy towels or bedding you have to be on hand to ensure a smooth take off!) so could one be fitted as an after thought , can they still be got ? I also thought id change the gearbox oil it currently has auto gbox transmission fluid in, the book says Shell Tellus 27 and i think a modern replacement is ISO AW 32 hydraulic , does anyone know where this may be sought ? Thanks again Richard. |
Post# 471170 , Reply# 1   10/24/2010 at 13:32 (4,929 days old) by electron1100 (England)   |   | |
Post# 471335 , Reply# 3   10/25/2010 at 14:02 (4,928 days old) by ricky5050 (Durham Britain)   |   | |
