Thread Number: 31210
liberator link of clip |
Post# 471157 , Reply# 1   10/24/2010 at 12:23 (4,931 days old) by justmadeit ()   |   | |
meant to add this edited link too for the ad CLICK HERE TO GO TO justmadeit's LINK |
Post# 471169 , Reply# 3   10/24/2010 at 13:14 (4,931 days old) by electron1100 (England)   |   | |
Hello justin
I have a very similar machine to this which has a slight leak also, in my case i found the leak was coming from the cast metal backplate on the tub, the metal itself has been eaten away by years of washing powder attacking it. I took the back off and put the machine on a wash cycle as the drum was turning tiny drops of water were appearing on the struts on the backplate, when i investigated where the water was appearing, i pressed on the metal and a hole appeared. I filled the holes with liquid metal but more have since appeared Now this may not be the case with yours at all hopefully it isnt but it is worth your while checking this out, because hosepipes or the pump would be easy to and cheap to change where as the backplates for these machines are very rare. Gary |
Post# 471276 , Reply# 4   10/25/2010 at 06:49 (4,930 days old) by hotpoint9534 (UK)   |   | |
As far as I know, the backplates for these machines are still available from Hotpoint. Tom. |
Post# 471363 , Reply# 5   10/25/2010 at 15:06 (4,930 days old) by electron1100 (England)   |   | |
Post# 471508 , Reply# 6   10/26/2010 at 08:40 (4,929 days old) by justmadeit ()   |   | |
have put another clip up of it spinning as requested. |
Post# 471725 , Reply# 8   10/27/2010 at 13:01 (4,928 days old) by justmadeit ()   |   | |
i initially said i was selling it {the liberator) on sunday the 7th, i meant to put the 31st of oct. so will be in touch with the winning bidder soon. im amazed that parts are still available for this ? |
Post# 471747 , Reply# 10   10/27/2010 at 13:45 (4,928 days old) by matchboxpaul (U.K)   |   | |
Hi Justin Fingers crossed your 1851/03 finds a good home. Whoever takes it on, will be justifiably proud I am sure. Paul |
Post# 471750 , Reply# 11   10/27/2010 at 13:48 (4,928 days old) by justmadeit ()   |   | |
a couple more pics to go with the ones ive added on a few other threads |
Post# 471751 , Reply# 12   10/27/2010 at 13:49 (4,928 days old) by justmadeit ()   |   | |
and another |
