Thread Number: 3128
Neptune MAH8700 washer is my load really clean and what's that ping |
Post# 80648 , Reply# 2   8/28/2005 at 09:39 (6,787 days old) by toggleswitch (New York City, NY)   |   | |
speaking of water pumps... It used to be that long horizontal or vertical runs of the drain hose would cause water to flow back into the machine after pumping stopped. With a (long) horizontal hose the water in it gets stangnant and stale, and the machine re-fills with yuckies. Aa check-valve helps in these situations, but are prone to clogging. Just a thought and hope this helps. |
Post# 80784 , Reply# 6   8/29/2005 at 10:20 (6,786 days old) by toggleswitch (New York City, NY)   |   | |
Post# 82912 , Reply# 7   9/12/2005 at 10:03 (6,772 days old) by FrontLoadFan (Wellfleet, Ma.)   |   | |
Hey Bushmaster - Don't leave us in suspence. What happened with your ping and musty smells? |
Post# 83489 , Reply# 9   9/16/2005 at 00:59 (6,769 days old) by bushmaster ()   |   | |
How high is your water level in the Neptune MAH8700. Mine is now just above the ribs in the tube. How high is yours.... -Rob |
Post# 83594 , Reply# 11   9/17/2005 at 10:13 (6,767 days old) by washoholic (San Antonio, TX)   |   | |
Rich, you wrote: Its great that the Big Boxes will allow you the option of exchanging the machine if you are not satisfied. Something tells me that this probably extends only for within a month of purchase. That’s probable true except for Sears. Sears always seem to go the extra mile when it comes to making sure someone is satisfied. One example is when I bought a dryer from Sears and 6 months later bought the matching washer, (Calypso) and when the washer failed and I returned it; Sears also let me return the dryer which was 7 months old and put the full purchase price towards the new matching set (Neptunes w/ the touch screen). No one stands behind their products, and cares about their customer’s satisfaction more than Sears! |
