Thread Number: 31297
CODE BLUE, I NEED BEARINGS STAT!!! |
Post# 472452 , Reply# 4   10/30/2010 at 21:31 (4,920 days old) by supremewhirlpol ()   |   | |
My Neptune has security torx screws that hold the door and front panel on the machine. There are 2 on both sides of the door. |
Post# 472453 , Reply# 5   10/30/2010 at 21:32 (4,920 days old) by supremewhirlpol ()   |   | |
Hinges need to be replaced too, That will have to come later. |
Post# 472454 , Reply# 6   10/30/2010 at 21:34 (4,920 days old) by supremewhirlpol ()   |   | |
Remove the door, remove the front panel. Looks nasty! |
Post# 472455 , Reply# 7   10/30/2010 at 21:35 (4,920 days old) by supremewhirlpol ()   |   | |
A lot of that crud is actually soap-> more about that later. |
Post# 472460 , Reply# 8   10/30/2010 at 21:58 (4,920 days old) by supremewhirlpol ()   |   | |
The top is held down by a lock bracket on each side of the machine and the top of the of the dispenser |
Post# 472461 , Reply# 9   10/30/2010 at 21:59 (4,920 days old) by supremewhirlpol ()   |   | |
lock bracket |
Post# 472463 , Reply# 10   10/30/2010 at 22:02 (4,920 days old) by supremewhirlpol ()   |   | |
The top of the dispenser is held on by 4 Philips screws. |
Post# 472465 , Reply# 11   10/30/2010 at 22:04 (4,920 days old) by supremewhirlpol ()   |   | |
Top comes up |
Post# 472466 , Reply# 12   10/30/2010 at 22:06 (4,920 days old) by supremewhirlpol ()   |   | |
Looks Gnarly! |
Post# 472468 , Reply# 13   10/30/2010 at 22:12 (4,920 days old) by supremewhirlpol ()   |   | |
In order to remove the outer drum, the dispenser has to be removed, along with the counter-weight, wiring for swiches/sensors, hoses, motor wire harness, lower drum out of balance switch, springs. |
Post# 472471 , Reply# 14   10/30/2010 at 22:16 (4,920 days old) by supremewhirlpol ()   |   | |
Hose in the middle of the top of the drum, has to go-> it's goes from the dispenser to the outer drum. Also remove sensor next to the hose. |
Post# 472473 , Reply# 16   10/30/2010 at 22:24 (4,920 days old) by supremewhirlpol ()   |   | |
Remove counter-weight->save/separate which bolts, screws go where |
Post# 472474 , Reply# 17   10/30/2010 at 22:26 (4,920 days old) by supremewhirlpol ()   |   | |
Remove the door lock module->2 screws on each side hold it in place. |
Post# 472475 , Reply# 18   10/30/2010 at 22:28 (4,920 days old) by supremewhirlpol ()   |   | |
Tilt forward and remove. |
Post# 472491 , Reply# 19   10/30/2010 at 23:13 (4,920 days old) by supremewhirlpol ()   |   | |
The front bottom of the outer tub can be removed by two bolts on each side->move it out of the way |
Post# 472493 , Reply# 20   10/30/2010 at 23:14 (4,920 days old) by supremewhirlpol ()   |   | |
Remove the drain hose. |
Post# 472498 , Reply# 21   10/30/2010 at 23:21 (4,920 days old) by supremewhirlpol ()   |   | |
Remove the harness to the motor from the control board. |
Post# 472499 , Reply# 22   10/30/2010 at 23:24 (4,920 days old) by supremewhirlpol ()   |   | |
Remove the front of the outer drum->the front of the outer drum is held on by a series of small clips. Just remove the clips, do not remove the boot!! |
Post# 472500 , Reply# 23   10/30/2010 at 23:25 (4,920 days old) by supremewhirlpol ()   |   | |
Here is what the clips look like. |
Post# 472503 , Reply# 24   10/30/2010 at 23:28 (4,920 days old) by supremewhirlpol ()   |   | |
The front is also held to the frame of the machine by 4 bolts->remove those, carefully remove the outer tub front and boot. |
Post# 472504 , Reply# 25   10/30/2010 at 23:34 (4,920 days old) by supremewhirlpol ()   |   | |
To remove the cylinder, locate the three big baffles, each baffle if held to the cylinder by 2 torx screws. Remove the screws, and baffles. |
Post# 472505 , Reply# 26   10/30/2010 at 23:36 (4,920 days old) by supremewhirlpol ()   |   | |
Removing the baffles exposes three bolts that hold the cylinder to the spider assembly. |
Post# 472666 , Reply# 29   10/31/2010 at 20:23 (4,919 days old) by supremewhirlpol ()   |   | |
One bolt holds the pulley into place->usually this bolt is on VERY tight. |
Post# 472670 , Reply# 30   10/31/2010 at 20:30 (4,919 days old) by supremewhirlpol ()   |   | |
Remove the spider assembly->Screw the bolt back on to the shaft, use a hammer to release the spider assembly from the bearings. Hit ONLY the bolt, otherwise if you divert from the bolt, you WILL damage the shaft. |
Post# 472673 , Reply# 32   10/31/2010 at 20:36 (4,919 days old) by supremewhirlpol ()   |   | |
Top view of the spider and one of the spacers. |
Post# 472676 , Reply# 34   10/31/2010 at 20:49 (4,919 days old) by supremewhirlpol ()   |   | |
The front bearing requires a bigger diameter pipe. In my case this bearing was the hardest to remove. It took ~30 minutes of solid pound to get it out. Here is the pipe afterward |
Post# 472677 , Reply# 35   10/31/2010 at 20:50 (4,919 days old) by supremewhirlpol ()   |   | |
rear bearing and collar |
Post# 472678 , Reply# 36   10/31/2010 at 20:55 (4,919 days old) by supremewhirlpol ()   |   | |
As you can see it is impossible to confuse which bearing goes where, or how far they have to go in. Also there is a weep hole for water run off |
Post# 472679 , Reply# 37   10/31/2010 at 20:57 (4,919 days old) by supremewhirlpol ()   |   | |
Where rear bearing goes. |
Post# 472680 , Reply# 38   10/31/2010 at 20:59 (4,919 days old) by supremewhirlpol ()   |   | |
Both bearings-> they do differ in size. |
Post# 473074 , Reply# 41   11/2/2010 at 19:38 (4,917 days old) by supremewhirlpol ()   |   | |
Here is a picture of the new vs old bearings. |
Post# 473077 , Reply# 42   11/2/2010 at 19:42 (4,917 days old) by supremewhirlpol ()   |   | |
Here is the collar, I cleaned it up a little, BUT again I don't want to change the bore sizes. |
Post# 473083 , Reply# 45   11/2/2010 at 20:02 (4,917 days old) by supremewhirlpol ()   |   | |
New bearing inserted into rear of outer tub. |
Post# 473085 , Reply# 46   11/2/2010 at 20:07 (4,917 days old) by supremewhirlpol ()   |   | |
You want the 12002022 Seal kit from FSP. This kit has seals for both the new and old tub styles. The kit also has instructions. |
Post# 473087 , Reply# 48   11/2/2010 at 20:26 (4,917 days old) by supremewhirlpol ()   |   | |
bearing spacer installed |
Post# 473088 , Reply# 49   11/2/2010 at 20:27 (4,917 days old) by supremewhirlpol ()   |   | |
Old metal spacer coming off shaft. |
Post# 473089 , Reply# 50   11/2/2010 at 20:29 (4,917 days old) by supremewhirlpol ()   |   | |
New seal being installed with provided tool. |
Post# 473090 , Reply# 51   11/2/2010 at 20:30 (4,917 days old) by supremewhirlpol ()   |   | |
Seal installed |
Post# 473091 , Reply# 52   11/2/2010 at 20:32 (4,917 days old) by supremewhirlpol ()   |   | |
Spider assembly shaft cleaned with new plastic ring seal. |
Post# 473092 , Reply# 53   11/2/2010 at 20:34 (4,917 days old) by supremewhirlpol ()   |   | |
Shaft coming out the rear of the outer tub(shaft just inserted) |
Post# 473093 , Reply# 54   11/2/2010 at 20:37 (4,917 days old) by supremewhirlpol ()   |   | |
Starting to put things back together-> it's best to install the motor while the tub is still out of the machine. |
Post# 473096 , Reply# 56   11/2/2010 at 20:47 (4,917 days old) by supremewhirlpol ()   |   | |
plastic spacers |
Post# 473097 , Reply# 57   11/2/2010 at 20:50 (4,917 days old) by supremewhirlpol ()   |   | |
Testing shows that the boot needs to be replaced. |
Post# 473098 , Reply# 58   11/2/2010 at 20:52 (4,917 days old) by supremewhirlpol ()   |   | |
Test wash with items that got very dirty with repair |
Post# 473099 , Reply# 59   11/2/2010 at 20:55 (4,917 days old) by supremewhirlpol ()   |   | |
Cycle complete-> no leaks from bearing area. Machine is very quiet. The only thing I hate about this machine is no window. There are still repairs that need to be made-> boot, paint, refinish area around dispenser. |
Post# 473101 , Reply# 60   11/2/2010 at 20:57 (4,917 days old) by supremewhirlpol ()   |   | |
Commercial Neptune IN-> Calypso OUT!!! |
Post# 473115 , Reply# 61   11/2/2010 at 22:57 (4,917 days old) by cfz2882 (Belle Fourche,SD)   |   | |
thanks for all that!-i now know what i am in for if the bearings go in my neptune... I did do a bearing job on my '98 frigilux,was actually pretty easy job on the frigilux. |
Post# 473227 , Reply# 62   11/3/2010 at 13:39 (4,916 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Post# 473243 , Reply# 63   11/3/2010 at 14:46 (4,916 days old) by vivalalavatrice ()   |   | |
to you! It's really a challange each times you have to replace bearings, but I see a very great job! BYE Diomede |
Post# 473286 , Reply# 65   11/3/2010 at 20:09 (4,916 days old) by A440 ()   |   | |
Awesome Job! You make it look so easy! |
Post# 473581 , Reply# 66   11/5/2010 at 19:50 (4,914 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 473693 , Reply# 67   11/6/2010 at 14:43 (4,913 days old) by yogitunes (New Jersey)   |   | |
Excellent job!
I have 2 neptunes, changed bearrings on both, first time, really took me a while, wasn't sure what I was geting into, so it took longer, second one went faster............ you really stripped off a lot more from your machine than I did I didn't take off the counter weights, or remove the inner tub from the spider, but yeah, getting those bearrings out was murder.....it went back together faster than I took it apart... I had to place the outter tub over 2 chairs, slide the inner tub with spider into place, and step inside with my full weight just to get it to seat onto the seal, even with a little vaseline, it fits tight..... so are you ready to do this again? |
Post# 477543 , Reply# 69   11/25/2010 at 20:38 (4,894 days old) by fordtech ()   |   | |
Great job and thanks very much for taking the time to walk us through it. I plan to run my Neptunes 15 more years with lots of parts procured from Ebay in storage. |
Post# 477586 , Reply# 70   11/26/2010 at 01:18 (4,894 days old) by qsd-dan (West)   |   | |
Post# 477602 , Reply# 71   11/26/2010 at 05:23 (4,893 days old) by fordtech ()   |   | |
Thanks! I wouldn't trade them for anything on the market today. |
Post# 478120 , Reply# 75   11/28/2010 at 15:21 (4,891 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 478315 , Reply# 78   11/29/2010 at 12:36 (4,890 days old) by fordtech ()   |   | |
supremewhirlpol I found this pic of an old switched reluctance motor from the early Neptunes on Ebay... this is the one that Whirs when it runs. The new models are virtually silent. |
Post# 478484 , Reply# 80   11/30/2010 at 11:04 (4,889 days old) by PeterH770 (Marietta, GA)   |   | |
