Thread Number: 31338
Dishwasher Rinsing |
Post# 473043   11/2/2010 at 17:08 (4,916 days old) by LLMaytag (Southern California)   |   | |
I'm curious, which of the new model dishwasher models have the most rinses after wash? My Whirlpool has the single purge then one full rinse after most cycles, and only two full rinses for the Pots & Pans or Hi-temp cycles. I always use a Hi-temp or Pots & Pans because I don't think that very short purge and one rinse is enough.
Post# 473116 , Reply# 1   11/2/2010 at 22:58 (4,915 days old) by appnut (TX)   |   | |
You know how to get around the situation that you do not like. What's the problem? Whirlpool makes KitchenAid, Kenmore, Maytag, and their own brand. That leavse Frigidaire which is basically crap. Electrolux is a gloried Frigidaire. GE is the onhly domestic brand that offers more than one rinse but most machines now have soil sensors which automatically reduce rinses unless you use the same type of options. Bosch probably has 2 rinses after wash on the normal cycle. That's about it. I have a Kenmore Elite and I have no problems with the single main rinse after the purge. also my soil level is high enough it automatically opts for the higher soil level and rinse instead of purge. U.S. dishwashers have to adhere to DOE Energy Star goals. I recently saw a lady complain about her GE not washing or drying as well as her frien's Bosch. I guess she didn't get out the two manuals and compare how each approaches washing. For the most part, the Bosch has higher water temp targets as default values for its cycles. The GE defaults to lower water tempts and the user has to selct the higehr heat options to equal what the Bosch does standard. Same way when KitcgenAid was sourcing its drawer dishwashers form F&P. Coomparable wash cycle labels. The U.S. version, pretty much all the cycles were the equavelent of the F&P cycles but with the eco option selected for each of those cycles. bottom line, in order to get more of what you're "used to from the old days" out of a modern dishwasher, you have to opt for the more aggressive cycles and higher temp options. It's reality.
Post# 473178 , Reply# 2   11/3/2010 at 09:21 (4,915 days old) by logixx (Germany)   |   | |
Our Bosch will do two or three rinses after the main wash - even on Quick Wash. It can also add purges before and/or after the first rinse. I am 99% sure Miele will also run at least two post-wash rinses. Euro dishwashers can get away with running more rinses because the fill with less water than US machines.
Alex |
Post# 473214 , Reply# 3   11/3/2010 at 11:48 (4,915 days old) by jlbrazil (brazil)   |   | |
My Whirlpool (made in germany) usually does 2 rinses , rarelly only one , but then when it rinses only 1 time she increases the temperature (70-75) to compensates the only one rinse :) |
Post# 473215 , Reply# 4   11/3/2010 at 11:56 (4,915 days old) by LLMaytag (Southern California)   |   | |
Yes, Frigidaire dishwashers are pretty crummy. When my Mom moved about a decade back, there was a new BOL Frigidaire tall tub. Ugh! Miserable performance. Didn't clean well, and if you didn't pre-rinse dishes it left all kinds of crap in the tub. We replaced it with a Kenmore sensing short-tub which is much better. I tell my Mom to always use the hi-temp option to assure two full rinses.
(Funny, story on the Kenmore. When it was installed the detergent dispenser wouldn't open. Two repair guys came out, replaced the motor/solenoid that releases the detergent door twice and were ready to replace the who machine until I went over one night and realize that the lower rack was in backwards!) My Whirlpool is a short tub, (cannot recall the model), with silverware in the door (anywhere basket), and I usually use the Normal wash with hi-temp to get a full pre-rinse and two full final rinses. I still feel compelled to rinse again afterward which I used to do with my old dial machine. On the dial machine, when it would fill for the final rinse, I could turn it back to the "rinse and hold" spot which would effectively give me three rinses, with only the final getting the rinse aid. On the new machine, I can't really do that. I can do a rinse-only afterward, but I know I don't get the hi-temp or the rinse aid. |
Post# 473222 , Reply# 6   11/3/2010 at 13:05 (4,915 days old) by Toggleswitch (New York City, NY)   |   | |
Quote: I could turn it back to the "rinse and hold" spot which would effectively give me three rinses, with only the final getting the rinse aid. On the new machine, I can't really do that.
I almost shot myself when I didn't think of this earlier. Just re-start your "computer" controlled machine on any cycle and then hit cancel after a rinse or two........ It will automatically drain and cancel. in the case of my Maytag DW it will add a drop of water to keep the sensor properly covered. The only thing being accomplished by all this energy-star hype is that automatic machines are now semi-automatic in the sense that that to get acceptable results one has to flush -- er run-- it twice. |
Post# 473239 , Reply# 7   11/3/2010 at 14:23 (4,915 days old) by DADoES (TX, U.S. of A.)   |   | |
