Thread Number: 31475
Timer for Maytag DG106 needed? |
Post# 474779   11/13/2010 at 08:26 (4,912 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 474802 , Reply# 1   11/13/2010 at 09:31 (4,912 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 474805 , Reply# 2   11/13/2010 at 09:46 (4,912 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
That doesn't look like a HOH dryer to me the door is too large. In any case I believe a dryer this basic only has one operating thermostat. Yes it could be a bad timer but I would be sure that its really consistent about heating fine on premapress. Try drying a large load of towels on PP and see if it works. If it starts to not heat it could be bad gas valve coils, if it is the timer its very easy to test with a volt meter or ohm meter and you should be able to clean and or adjust the heat contact in the timer.
Post# 474863 , Reply# 3   11/13/2010 at 15:01 (4,912 days old) by redcarpetdrew (Fairfield, CA)   |   | |
Post# 474866 , Reply# 4   11/13/2010 at 15:15 (4,912 days old) by moparwash (Pittsburgh,PA )   |   | |
Post# 474875 , Reply# 5   11/13/2010 at 16:29 (4,911 days old) by moparwash (Pittsburgh,PA )   |   | |
