Thread Number: 31715
Speed Queen Dryer "Leaking" water!? |
Post# 478390   11/29/2010 at 18:57 (4,889 days old) by danmantn (Tennessee)   |   | |
I got a call from some friends staying at the condo--stated the dryer was "leaking"! After laughing and calling them crazy, sure enough...I Googled it and seems that a clogged dryer vent will cause this? Oh no, not more dryer vent problems.
ARGH! I won't get back down until next week--wanted to post on here and see if you all agreed? |
Post# 478403 , Reply# 1   11/29/2010 at 19:55 (4,888 days old) by qsd-dan (West)   |   | |
Post# 478405 , Reply# 2   11/29/2010 at 20:24 (4,888 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
This is a fairly common problem if the vent is clogged the hot humid air is forced into the vent stack and the moisture condenses and runs back down the vent hose or pipe and the water either leaks out of the vent or runs back through the dryer and leaks. It has little or nothing to due with how well the washer is spinning. The one thing that people forget to tell you is they are having to run the dryer 3 hours to get anything dry, and people wonder why the darn thing caught fire.
Post# 478408 , Reply# 3   11/29/2010 at 20:49 (4,888 days old) by danmantn (Tennessee)   |   | |
Post# 478409 , Reply# 4   11/29/2010 at 20:53 (4,888 days old) by laundromat (Hilo, Hawaii)   |   | |
When I lived in Florida and worked at a Maytag dealership, a lot of customers would come in to buy a new dryer and would wonder why their current one took so long (1.5 to 4 hours) to dry their clothes. Being the person I am who loves doing laundry, I asked them what the set up was regarding the venting of their dryer. 99% of them told me the dryer they had in their garage,a laundry room or the kitchen was vented up through their attic or roof.I explained to them there was no need to replace their dryer (I hated when they wouldn't listen because the new ones would always come back)and to return home,place a wet load in,remove the vent and run the load through. If the clothes dried any faster, the unit needed to be properly vented and not to vent it any higher than 4.5 ft. and no longer than 15 feet from the dryer.At first, my boss was furious for me not selling them new dryers but,once the folks I helped began sending more business,he shut his face.Most of the current house fires are from careless mistakes like this.Not only does the build up of lint cause the flames to sore but,the static electric charges that occur in the vent hose or blower assembly are also to blame.Furthermore, the strain of the motor and overheating can cause any new dryer to have a much shorter lifespan.I know at least a dozen folks who had to replace their new dryer within a 2 year lifespan.Some were expensive like the Neptune, Duet and Kenmore models.
Post# 478417 , Reply# 5   11/29/2010 at 22:20 (4,888 days old) by danmantn (Tennessee)   |   | |
Post# 478615 , Reply# 6   11/30/2010 at 23:07 (4,887 days old) by danmantn (Tennessee)   |   | |
Well, checked out the SQ dryer tonight...seems that the 90° elbow that I had installed (to vent out the left side of the dryer) came loose and all the moist hot air was going into the bottom of the dryer, condensing, and dripping. I tightened the clamp back on the elbow and will monitor--don't want to use duct tape, yet.
Happy that it wasn't a clogged exhaust pipe as I just had that thing cleaned a few months ago. All is well. :) |
Post# 478741 , Reply# 8   12/1/2010 at 16:55 (4,887 days old) by danmantn (Tennessee)   |   | |
Post# 478778 , Reply# 9   12/1/2010 at 20:26 (4,886 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
While a smooth elbow would be better its really the short 90 degree turn that is so restrictive to air flow. When ever possible I use two 45 degree turns to avoid the tight turns in dryer vent systems. Its far better to plan and install a good vent system as opposed to trying to use a booster fan, the booster fan can cause more problems than the dryer itself.
Post# 478935 , Reply# 10   12/2/2010 at 09:18 (4,886 days old) by danmantn (Tennessee)   |   | |
